Help installing 2nd hand 2048 MKII, PCI-324 on XP (no cd's)
fredimac
Post by fredimac »
I recently purchased a used MOTU 2048 w/ pci-324 card.
I installed the card in my PC, installed the drivers and the system was happy.
However, when I connect the 2048 with a Firewire cable (not the original) nothing shows up in the "Configure Interface" drop down list in the console.
I don't have the original CD's. Do I need the Configuration Wizard? If so, how do I get it?
Thanks,
Fred
TrakMstrE
Post by TrakMstrE »
What slot is the 1394 F/W cable plugged into on the PCI-324? It should be in the "inner-most" slot, the one next to the round serial port (the RS422 DIN-8 port).
Also, it should not be longer than 30 feet....
innerlogicmarty
Post by innerlogicmarty »
Maybe try some of the older 324 drivers. I had the same problem but with the help from some guys on this forum I found drivers that I tried and with one of these drivers I got my 2408 MkI perfectly working on my pc (on a different machine I even got it working with the newest drivers, motherboards can be a bitch). Search the forum for pci 324 drivers and you'll find links to them.
innerlogicmarty
Actually, a topic a little below this one already gave the link to the 03-26-03 drivers for the 324. Try those:
http://www.motunation.com/forum/viewtopic.php?t=9144
fredimac
Post by fredimac »
Thanks All Y'all for your advice. I'm gonna go to the studio and give it a try. Unfortunately I don't have internet access there yet so I have to go back and forth on this.
Will keep you posted.
~ fredimac
innerlogicmarty wrote:Actually, a topic a little below this one already gave the link to the 03-26-03 drivers for the 324. Try those:
