Do other people get cold while using the Apple Magic Mouse?
- mhschmieder
I don't get cold easily, and generally don't turn the heat on until it goes down to 48 degrees (or 52 degrees with humidity), and even then I only turn it to 55, 58, or 60 degrees.
So perhaps I am the only one who gets a chill while using the Apple Magic Mouse, but it bothers me as it causes me to be inclined to turn the heat on when I wouldn't otherwise, or to turn it higher.
That's especially not cool during a session, of course (noise).
I did a web search and found NOTHING, yet it is logical this would be the case as the mouse's base (which is gripped most of the time while using it) is metal. I may need to switch to an all-plastic mouse.
Re: Do other people get cold while using the Apple Magic Mou
I tend to run on the warm side myself, but I do know that long periods of physical inactivity at the computer can make me feel chilly.
Fingerless gloves can work wonders.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.34
- buzzsmith
Two completely uneducated guesses...
1. Gripping the mouse may reduce blood flow to your fingers?
2. Raynuad's Syndrome? (I have this.)
Buzzy
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- FutureLegends
For me it's more about sitting still in front of the computer... but that's not dependant on what mouse I'm using...
- Kurt Cowling
These are made by a violist in the Milwaukee Symphony. I have a couple pair for occasional outdoor gigs:EMRR wrote:Fingerless gloves can work wonders.
https://www.etsy.com/shop/PositivePuffi ... ount#items
DP 11.34 , 2021 MacBook Pro M1-Max, 2017 iMac Retina 5K 27-inch, Omnisphere, Trilian, Stylus RMX, EZ Drummer 2, Falcon, Real Guitar, Sample Modeling brass. Audio Modeling reeds, strings, Kontakt 6, Flux Pure Limiter 3, PSP Vintage Warmer, PSP MixPack, PSP StereoPack, PSP Impressor, Altiverb 7, Izotope RX10 Standard, Yamaha S-90ES, Yamaha MOXF-8, Yamaha MX60, Sibelius subscription, Adobe CC and Motion 5.
Or just the fingas [sic] off a pair of gloves. A little stitching and you're good to go. Y'all sew, dontcha?Kurt Cowling wrote:These are made by a violist in the Milwaukee Symphony. I have a couple pair for occasional outdoor gigs:EMRR wrote:Fingerless gloves can work wonders.
- Kurt Cowling
I found these less restrictive by just going around the thumb and wrist. Actual gloves with the fingers cut off make me feel like I’m working against the glove to play larger stretches.
Maybe a small heating pad on the underside of your desk where the mouse lives.
Thinking this might be nice behind my back when mixing late at night...wylie1 wrote:Maybe a small heating pad on the underside of your desk where the mouse lives.
- mhschmieder
It's 59 degrees now and I'm not experiencing chills, so there must be some cut-off point where skin-to-metal contact starts to have an effect on me. Metal by its nature will feel colder in the relative sense, so it's a matter of degree (no pun intended).
I had bought another mouse early this year to try out at work, but it ended up needing some "extra" device that wasn't part of the package and which became a time-consuming research task that I never had time for. Once our office reopens next week, hopefully I can figure it out and order the part. If that mouse works well, I'll buy one for the home as well.
The Magic Mouse is the first Apple mouse is have not only not detested but have liked quite a bit. But I'm rather outdone with how quickly its battery runs down, and how it takes almost a full day to recharge. I spent $300 on OWC's new Thunderbolt 3 hub with high-power USB slots, which should arrive by next week. We'll see how long it takes to recharge then.
What is your desktop made of? Some materials (like granite or other stone—real or man-made) will definitely suck the heat from your body.
- mhschmieder
A wood slab on top of metal. But it's only specifically the metal edges of the mouse where I ever start feeling coldness transmit to my body.
I'll look at the other topic in the main forum where people are discussing the best mouse to use with DP. I was at Fry's today but stock was super-low due to the aftermath of holiday shopping.
I notice there's also heated mouse pads
- mhschmieder
Only problem with mouse pads is that most newer mice don't like them.
The other topic in the main forum made it clear that Magic Trackpad 2 is the way to go.
I have one at work that I never found time to unpack and learn how to use, so will hopefully have time to do that this week, once our office reopens from the end-of-year shutdown.
