OS 10.7.5 and Quicktime 10.1 Screenrecord
Klaus
Post by Klaus »
I know I'm behind...
just tried a screen record with QT10.1, audio source set to Motu896mk3h.
and this is set as output device in audio MIDI set up...
The screen record window of QT 10.1 shows l and r signals coming in ok.
When I play back the screen record.mov, I get sound only on the left channel, but probably double as loud, like if the right channel is recorded on the left side as well.
Bug in 10.7.5 / QT 10.1 ?
I tried on another mac with 10.7.5 that has soundflower 1.6.6b installed, and routed to / from via soundflowerbed.
Works ok.
Installed soundflower 1.6.6b on the 'problem' Mac and routed to / from soundflower and it works ok.
Anyone has hints if this is a bug in 10.7.5 / QT 10.1 ?
and best regards
Klaus
