Area to place playback head in Timeruler is WAY to small...
Prime Mover
Post by Prime Mover »
My audio job is incredibly tedious. I listen to field recordings for any minuscule ticks or distracting noises and snip them out. I think I once calculated around 800 snips in a 5minute region. When you're doing a routine over and over again, the little annoyances become huge. There are not many, but the big one, and I realize it's ALWAYS been there, way before I did this kind of work, is that the vertical space along the timeruler to place the playback head is WAY too small, and has no visual delineation. It's maybe 10 pixels high, if that; an invisible region that extends only the height of the ~8pt time/measure numbers. Anything down in the ruler ticks changes to a selection cursor. Even when I'm careful, I miss maybe 15% of the time, and the whole process just adds just a little tension to my workflow.
I'd love to see a shading change between the "selection" region and the "play head" region, that would help A LOT. Secondly, I'd love to be able to change the height of the time ruler.
— Eric Barker
Eel House
Re: Area to place playback head in Timeruler is WAY to small
I agree that that area is pretty tight. However, I've gotten so used to finding it-- though it's invisible, the cursor change is all I ever needed.
I think of it as "up by the numbers" is the playback wiper cursor switch, on the ruler notches where I can select a time-range.
And.. HOLY CRAP... I just found something-- Right Click in that little strip right below the ruler to add a Key, Meter or Tempo Change. Never knew that was there.
Phil O
Post by Phil O »
stubbsonic wrote:Right Click in that little strip right below the ruler to add a Key, Meter or Tempo Change. Never knew that was there.
Wow. Good find. I never knew that was there either! 8)
It also gives you a from/to option so if you change the key it will add another change back to what it was prior to the change. It also brings up the tempo change window so you can insert ramps, etc. It's more full featured than using the Conductor Event list.
Sorry to hi-jack the thread. But this is pretty cool.
But yea, fiddly that wiper area.
Is there a command to change the cursor to the wiper?
My paradigm for doing that kind of detail rarely gets me out of the sequence window (with the soundbite zoomed way in). Once I find the little bastards I use the 4 and 6 numeric keys to toggle around it. I rarely touch the wiper.
Helen
Post by Helen »
Way late reply, but I so very wanted to say THANK YOU for posting the right click technique. I have become right click happy after you posted that, trying right click for several tasks that I used to use the menu or mouse over for. My gosh I am happy with this. Thankyouthankyouthankyou! :woohoo:
Mac Pro Rack 7,1 3.2 Ghz 16-core, OS 12.7.4, 192GB ram
MOTU 828es, DP 11.31, Altiverb, Kontakt 7, VEPro
This job is fun, this job is fun, this job is fun....
Oh cool! So glad that was a game changer for you. Yea, since I found that a few months ago, I've used it a few times. So nice when you can find a little step saver.
