Hey gang.....
Is anyone else having trouble bouncing AAC files out of DP 9.51? I’m getting an error message every time.
DP9.51 AAC B2D
DP9.51 AAC B2D
Re: DP9.51 AAC B2D
I didn't even know DP could bounce out a AAC. And yes, it works fine here.
Re: DP9.51 AAC B2D
Do you remember what settings you were using? The defaults?bayswater wrote:I didn't even know DP could bounce out a AAC. And yes, it works fine here.
Re: DP9.51 AAC B2D
I suppose it was all defaults.
First dialog:
Core Audio Export: AAC ADTS (.acc)
Second dialog:
Data Format: AAC
Sample Rate: Same As Source
Bit Rate Strategy: Variable
Bit Rate: 320000
Encoding Quality: High
First dialog:
Second dialog:
Data Format: AAC
Bit Rate: 320000
Re: DP9.51 AAC B2D
Thanks. I was fiddling with settings, so maybe I pissed it off. I’ll try the defaults.
