I currently have an Akai MPK 61 connected via USB, it also works via the MIDI jacks i/o as well. I've been trying to connect a Korg nanoKontrol controller ( it will only connect via USB) both the AKAI and the nanoKontrol are connected to a powered hub then to the computer. I have downloaded and installed the current Korg MIDI driver. I can not get the nanoKontrol to show up in my audio MIDI setup allowing me to attach a fader or button as a MIDI CC for any track in DP 7.24 or as an input to any of my VI(s) … I've changed usb cables. Anything come to mind… Many thanks in advance - Jim
( I'm expecting my DP 9.5 update any day BTW)
DP > nanoKontrol a no go …
Schweats
MacPro 2.8/OS 10.10.1/6g ram/Powerbook G4/1g ram/10.4.11/828 mk3 hybrid/MTP AV usb/DP 7.23/Stylus RMX/Omnisphere/Trilian/Mach Five v2/RealGuitar/Korg Oasys/UAD2-Quad card & various plugs/Novation Zero SL mk2 controller/Akai MPK61
Re: DP > nanoKontrol a no go …
for testing try bypassing the hub
your Audio MIDI Setup / NanoKontrol will likely look something like this when it's working:
MacBook Pro 9,1 15" 16gb | 10.12.4 | DP 9.13 | xAir | NI | WIVI | Garritan | Izotope | Bidule
Thanks mate, that was the problem. … and BTW, I use a Kensington Turbo mouse Pro and I had it connected to the hub also and every time I started it would never see the mouse until I unplugged it from the hub , then plugged it back in. Now I have the trackball plugged into the USB port on the Mac keyboard which in turn is plugged into the hub and it 'sees' the trackball every time… go figure
Schweats
- Gravity Jim
Are you using a powered hub? If not, I'd get one. Eliminates a lot of common problems.
Jim Bordner
