Also, is there a way to prevent this in the future?
Yup. Not ideal, but it works great while MOTU fixes the problem. Fades should still be there even after sample rate conversions or whatever.RodneySauer wrote:One solution, if you are sure you like your cross fades, is to merge all of the soundbites into a single soundbite, which of course removes all of the cross fades and incorporates them into the new soundbite.
Since it is specifically designed for audio, it probably compresses the audio portions more effectively, since there are things about audio data that are more "predictable" than the general data types for which zip compression is designed.bayswater wrote:Using RAR compression for Audio often works better than using ZIP. IIRC it exploits silence more efficiently.
Agreed, but occasionally I need to share projects by using dropbox or other filesharing sites, and upload/download times can be pretty ridiculous if you don't compact the project.HCMarkus wrote:I never compact projects. Hard drive space is cheap.
