Stereo option blanked out in 9.1 RESOLVED
Re: Stereo option blanked out in 9.1
Would inserting a mono plugin cause you to lose pan/bal functionality?
atemporarywind
Post by atemporarywind »
Hello Stubb,
definitely another thing to look into but the master fader and busses I had assigned plugins to only let me use Stereo versions of the plugins... however, I suppose if one leaked through without me noticing then maybe its possible... anything is possible at the moment.
thanks for the suggestion, I'll look into it as well.
Kurt Cowling
Post by Kurt Cowling »
Does your audio interface have its own console app? Any chance things are getting panned center there?
DP 11.34 , 2021 MacBook Pro M1-Max, 2017 iMac Retina 5K 27-inch, Omnisphere, Trilian, Stylus RMX, EZ Drummer 2, Falcon, Real Guitar, Sample Modeling brass. Audio Modeling reeds, strings, Kontakt 6, Flux Pure Limiter 3, PSP Vintage Warmer, PSP MixPack, PSP StereoPack, PSP Impressor, Altiverb 7, Izotope RX10 Standard, Yamaha S-90ES, Yamaha MOXF-8, Yamaha MX60, Sibelius subscription, Adobe CC and Motion 5.
atemporarywind
Good News Everyone, I'm an idiot.
Kurt's suspicions were correct, there was an outboard set up in Antelope Audio that was panned Mono and when I went left and right with it, it all unfolded into a beautiful world of panning.
it also made my mono mix sound like hot garbage. :/
Thank you all for your suggestions and insights.
Hopefully I'll get well enough versed in the world of DP to be of help to someone down the line as opposed to just yelping for answers.
Be well,
-J
Kurt Cowling
Glad the problem is solved. I'll also mention that I see in your screen shot that you've got panning on some stereo tracks. The panpot in DP is really a balance control on stereo tracks. Panning left just turns up the left channel and turns down the right channel.
I would suggest you leave the pan centered on stereo tracks and insert the "Trim" plugin, which gives you gain and pan for each side of the stereo track independently. I know it doesn't give the same visual feedback, but it gives you the ability to control the width of the stereo image and you don't lose the audio from one side when panning far.
atemporarywind
Thanks Kurt,
I actually utilized your tip on a mix last night with the Trim Plug in, brought a few things out in different ways that I hadn't tried before.
Thanks again for the tips and tricks. You should make videos about this stuff if you haven't already.
Kurt Cowling
Glad you found it useful!
