-connect directly to computer bypassing USB hubs
-connect to a different computer
-update driver
-perform factory reset (disastrous results - read on)
None of these helped
Also, there's a problem with Clockworks where the configuration I saved didn't load correctly into the interface. Before performing a factory reset, I saved my configuration in Clockworks. I had to make new connections in AMS, but after testing, the results were still the same. I still had to rescan in order for data to pass through other than the sync port. I then tried to reload my configuration and the interface went berserk. I had to recreate all my configurations all over again from scratch.
Has anyone seen this behavior? If so, how did you resolve it?
