This is very odd. Can they provide any info on how to duplicate the problem?HCMarkus wrote:My Tech Link Update to MOTU this evening:
Happy to get 9.5 and excited to use the new pitch/time tools. Thank you!
However, very sad to advise the CC64 bug is still present in 9.5. Please advise if any attention can be given. Thank you.
DP 9.1 sustain pedal not audible during recording
Re: DP 9.5 sustain pedal not audible during recording
They have not. Silence for some time from MOTU on this one. I understand I am not the only victim of this bothersome bug. The workaround is to record alternating tracks; as long as the are no MIDI notes later in the timeline on the track on which one is recording, CC64 works fine.cuttime wrote:This is very odd. Can they provide any info on how to duplicate the problem?HCMarkus wrote:My Tech Link Update to MOTU this evening:
Re: DP 9.1 sustain pedal not audible during recording - RESO
I'm the original creator of this thread and problem was solved since DP 9.12...I'm not sure if we are having the same problem~
Reading back over this thread, the first thing that comes to mind is %⊔@# PhotoBucket.
Sounds like it to me... I just reviewed your initial post. Not sure if the issue arose when trying to record a new pass over an old MIDI pass for you (you didn't specify) but, with that possible exception, your problem is EXACTLy what I experience now. And, as noted MOTU has indicated they have replicated the behavior. I just hope they fix it soon.jacey714 wrote:I'm the original creator of this thread and problem was solved since DP 9.12...I'm not sure if we are having the same problem~
PS: Jacey, would you be so kind as to edit the thread title to remove the "RESOLVED"? 'cause it sure ain't resolved for me! Thanks.
Re: DP 9.1 sustain pedal not audible during recording RESOLV
I tried setting up a new User Account in the studio Mac Pro. A pain in the arsenal, getting everything running correctly, but took the opportunity to update a few plugins along the way.
Why did I do this?
Because it fixed the CC64 bug. Apparently something in my other account was hosed; trashing preferences didn't fix the problem in that account. Neither did a complete clean reinstall of DP. But a fresh User Account did the trick and I will happily be reporting as such to MOTU once I post this.
Peace.
Why did I do this?
Peace.
coolness- finally
Mac Studio MAX 2TB/ 64GB RAM / DP11.2 / 828ES//
MP 5.1 3.33- 3 duo / OS10.14.6 / RX580 /DP10.13/828ES
Thanks Amigo. Nice when a little irksome thing that bugged just often enough to be a pain is banished. Plus the system tune up wasn't such a bad thing either.Tonio wrote:coolness- finally
Also, I alerted another user on the Facebook Group (the one you told me about Babs) and he erased the bug on his system with the New User Account approach.
I guess this thread can, once again, be marked "RESOLVED."
Glad you got this to work! Back when I had Apple Care I had a problem where DP would crash if I recorded WAV files, but not on a new account. I had a senior Apple tech who managed to bypass all the usual troubleshooting tips. What he did was log in remotely and migrate my system preferences from the new account to my previous user account, and it fixed the problem. Something you might want to look into, but make sure you have a good backup, of course. Another possibility would be to restore system preferences from a Time Machine backup from a time before the CC bug showed up.HCMarkus wrote:I tried setting up a new User Account in the studio Mac Pro. A pain in the arsenal, getting everything running correctly, but took the opportunity to update a few plugins along the way.
Why did I do this?
Good point. Interestingly, the issue arose when MOTU took DP to pre-gem. On my original User Account, I can still revert to 9.02 or 8.07 and not experience the CC64 bug. Now my system is running clean under the new User Account, I'll make a note of the date in case issues arise in the future, so TM can help me out. Thanks!cuttime wrote:Glad you got this to work! Back when I had Apple Care I had a problem where DP would crash if I recorded WAV files, but not on a new account. I had a senior Apple tech who managed to bypass all the usual troubleshooting tips. What he did was log in remotely and migrate my system preferences from the new account to my previous user account, and it fixed the problem. Something you might want to look into, but make sure you have a good backup, of course. Another possibility would be to restore system preferences from a Time Machine backup from a time before the CC bug showed up.HCMarkus wrote:I tried setting up a new User Account in the studio Mac Pro. A pain in the arsenal, getting everything running correctly, but took the opportunity to update a few plugins along the way.
Why did I do this?
