Unable to perform multiple tracks assignment
jsmusic
Post by jsmusic »
I've been experiencing problems assignment in/out puts to multiple tracks after reinstalling DP on my new Macbook, updated to the latest version of DP 9. In the past I was able to used Option+A to assign but now the button "OK" on the bottom is greyed out when I try to change output for multiple tracks or even one single track. I wonder if anyone is experiencing this problem too?
I note that this happens on both my new laptop and also my desktop version on Mac mini after I upgraded to the latest version. Any one who could help advise?
tommymandel
Re: Unable to perform multiple tracks assignment
Post by tommymandel »
Sometimes after a change of hardware, software, or :?: the moon :!: input names get changed. Check to see if that happened and the inputs are not the ones DP or Bundles thinks they are.
(That's probably not it, but when I experience that on my rig, that's usually the cause here. 8)
jsmusic
Post by jsmusic »
Thanks for your kind reply, shall check out as per what you suggested and see if that's the cause. :)
TinenTech
Post by TinenTech »
I'm still on DP 9.02, but Option-A seems to be working fine on my MBP.
What do you see when you click on the pull-down menu to assign inputs and/or outputs?
Are you clicking on "Assign all selected tracks to this input (output)" or "Assign to consecutive inputs (outputs)"?
MacBook Pro 9,1 (mid-2012 Core i7 2.3 GHz 4 GB RAM), OSX 10.11.3, Newertech Voyager SATA drive dock
MOTU: DP 9.02, Traveler Mk 1, 896 MkIII Hybrid, MIDI Express XT
Alesis AI3 optical interface, QS8, QS7, DM Pro, DM5, QSR
Mackie Controller and Extender (original MIDI)
Pro Tools 12
