Merge soundbites will create an independent audio region...So... if you want to have two different versions of the soundbite, and edit the pitch separately, you can do a little edge edit, or there is another command to create a copy of a soundbite. I can't remember it now.
How to decouple regions?
Re: How to decouple regions?
Alright,
that solved it now. Copying the region will not generate a new soundfile, unless you move the edge. As long as you only copy the region nothing will change, and pitch edit in the Pitch Layer will affect both regions. As soon as you touch the edge, it will list a new soundfiles in the soundfile tab, and now pitch edit will work on separate regions. It's a bit strange I must say, but anyway.
Does anybody know of any shortcut (command) for this, I would like to avoid touching the edge of an already edited region...
What also puzzled me is that I'm using the version that comes with a translation for German. And whoever did the translation put it the other way round. There is a difference between "Edge Edit (a) Copy" and "Copy Edge Edits", the latter of which will give you exactly the opposite result. He who did the translation decided for what I think is the wrong translation. Instead of "Randbearbeitung kopieren" in german (=copy all edge edits) it should be named "Bearbeite Kopie" (=edit a copy) and then be ticked in order to get independent regions. It's a bit of a brain twist, but just in case there is any other german user of DP9 here maybe you could check against this.
Thank you everybody for your help, I guess I will enjoy this forum. And maybe I better install the English version of DP 9 now...
Thanks MW1 - it does!Merge soundbites will create an independent audio region...
This is splitting hairs, but just to be clear: when you use MERGE SOUNDBITES, it will create an entirely new audio file, and add data to the project. There are times when you would want to do that. Like if you want to consolidate tracks, when you want another copy of the audio to do a destructive edit to, etc.
I'm almost positive there is another command, that will create a new soundbite (within the same file) that will work like an edge edit copy. It will have its own pitch layer, but share original data from the source file. I feel like we referred to it in a recent thread, maybe in the last 8 months.
Select your copied soundbite then choose "Duplicate Soundbite" from the Audio Menu.
This creates a completely new additional soundbite within the same audio file, such that any future pitch/fade/edge edits will only affect this 'duplicated' soundbite, leaving the original 'source' soundbite unaffected.
Mac Pro 'Nehalem' 2 x 2.66 Quad Core, 28GB, 10.11.6 || MacBook Pro 2.7 Intel Core i7 Retina, 16GB, 10.11.6 || MOTU 2408 Mk3, 828 Mk 2, MTP AV || DP 9.51 & 9.13, Mach 5 v3, MSI, Ethno2, MX4, VEPro6, all Spectrasonics, Kontakt ... and many of the other usual suspects.
http://www.thekeyboard.co.uk
That's the one!
Thanks to all of you,
as I said: I think I will enjoy this forum. I actually already do.
@stubbsonic
Nice music b.t.w.
Nice music b.t.w.
- philbrown
Peter your English is better than a lot of my US Facebook friends - no kidding!
Wow! Thanks for going and checking it out!peter wrote:@stubbsonic
Nice music b.t.w.
Oh, thank youphilbrown wrote:Peter your English is better than a lot of my US Facebook friends - no kidding!
Yeah, those were the days...
Cheers
Ha, see, it's still tricky:
Back then when I started what we now call homerecording...
Unfortunately it wasn't me who started it all. So: Back then when I started with what we now call homerecording...
As I said, still learning
