macOS Sierra 10.12.6
Re: macOS Sierra 10.12.6
No problems here.
On one of my Macs, the fans were idling a little fast after the installation. Rebooting again fixed that.
About the macOS Sierra 10.12.6 Update
This update is recommended for all macOS Sierra users.
The macOS Sierra 10.12.6 Update improves the security, stability, and compatibility of your Mac, and is recommended for all users.
Enterprise content:
Resolves an issue that prevents making certain SMB connections from the Finder.
Fixes an issue that causes Xsan clients to unexpectedly restart when moving a file within a relation point on a Quantum StorNext File System.
Improves the stability of Terminal app.
Enterprise content:
After I updated, Logic Pro X and MainStage showed updates in the App Store dated yesterday. As did iTunes, of course.
Is Adobe Acrobat working? Updating killed it on my wife's MacBook Pro. I so don't want to loose that (or start paying those f#%^&s a monthly fee.
That could be a deal breaker here as well.MIDI Life Crisis wrote:Is Adobe Acrobat working? Updating killed it on my wife's MacBook Pro. I so don't want to loose that (or start paying those f#%^&s a monthly fee.
Acrobat Pro X version 10.1.16 working fine here. I had to bypass GateKeeper to get it to install properly in an earlier build of Sierra but the OS update had no effect.MIDI Life Crisis wrote:Is Adobe Acrobat working? Updating killed it on my wife's MacBook Pro. I so don't want to loose that (or start paying those f#%^&s a monthly fee.
Acrobat XI isn't behaving since El Cap but I really disliked it compared to X so I have not bothered trying to get it working again.
Bypassing GateKeeper is now a PIA unless you use the following Terminal Command:
sudo spctl --master-disable
It can be re-enabled in System Preferences or with the following command:
sudo spctl --master-enable
Thanks man. I didn't even know about Acrobat XI. Otherwise, same version, so I guess I'll update.mikehalloran wrote: Acrobat XI isn't behaving since El Cap but I really disliked it compared to X so I have not bothered trying to get it working again.
With X Pro, Adobe should have just declared Acrobat done except to update the installer once Gatekeeper became a thing.
XI uses that same license server nonsense they went to with CS 6.
- mhschmieder
Amazingly, Photoshop and Illustrator CS6 still opened after the update.
Luckily, I don't use Acrobat "Pro".
Nothing to see here, I'm happy to report. All is well, including Acrobat Pro.
- Guitar Gaz
Bias Peak Pro 7 still working....
Gary Shepherd
____________
____________
I wouldn't call that being lucky. No pdf app comes close to some of the things it can do.mhschmieder wrote:Luckily, I don't use Acrobat "Pro".
- mhschmieder
BIAS Peak Pro 7 still not working... it's the last one left on my list at this point, except for Ivory, which will probably be sorted out soon by Synthogy/Ilio as they've been very responsive.
- mhschmieder
I can't afford Acrobat Pro, but I suppose it's good. Never had the chance to use it, EVER.
For reading PDF's, nothing touches Preview on the Mac -- though it's not as good as it was when it first came out. Maybe Acrobat Pro is a better reader; I just assumed it's the same as the awful free version, except for letting you edit/write.
There's also the 3D version, which can even import 3D data from AutoCAD.
- Guitar Gaz
It was not working for you on 10.12.5 either - I am just updating that it does work still on 10.12.6 for me and that the OSX update is not an issue.mhschmieder wrote:BIAS Peak Pro 7 still not working...
I am glad you got DSP Quattro working - that may point the way for Peak Pro to work on your system.
Gary Shepherd
____________
____________
