MX4 suddenly missing in DP 9.13
sacwest
Post by sacwest »
I upgraded to 9.13 a few weeks back, only to find out that it was buggy. So I "downgraded" to 9.12. Ever since that, I cannot find MX4 in my instrument plugins (I'm now using the improved 9.13)
I've gone into the preferences, where MX4 is shown and had it reexamined. Still nothing. Not sure what went wrong.
apanacci
Re: MX4 suddenly missing in DP 9.13
Post by apanacci »
Did you reinstall ? I think it is in the MAS folder under Library/Audio
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
reedster
Post by reedster »
You might check for multiple mx4.patches.backup files. Once those were removed from my system MX4 started showing up as expected.
MacBook Pro 9,1 15" 16gb | 10.12.4 | DP 9.13 | xAir | NI | WIVI | Garritan | Izotope | Bidule
sacwest
Post by sacwest »
reedster wrote:You might check for multiple mx4.patches.backup files. Once those were removed from my system MX4 started showing up as expected.
I found 7 mx4.patches.backup files. I threw them in the trash and restarted. However, it still isn't loading into the program - doesn't show up in "instruments".
In DP Preferences it's there and checked. I've even had it "reexamined". Still nothing. I'm wondering if I should just do a complete reinstall...
I would.
apanacci
Post by apanacci »
I get weirdness with DP plugins crashing the program. I remove them then do a complete reinstall of the program.
sacwest
Post by sacwest »
Well, life is getting more interesting! MOTU told me to place the folder com.motu.MotuAudioSystem on the desktop and restart DP. Now the Examiner is hung up on MachFive3. So.... looks like another problem has cropped up.
So, if I do a complete re-install of DP, what do I need to trash????
apanacci
Post by apanacci »
They did not recommend a reinstall ? Was MX4 in the MAS folder ? If it was, take it out and reinstall. Try that
apanacci wrote:I get weirdness with DP plugins crashing the program. I remove them then do a complete reinstall of the program.
No reason to do that. Just reinstall—the plugs will be overwritten. This resets the paths as well.
