I Haven't had time to install at the studio yet, as I've been working at another studio (using P.T) but hopefully it will be sorted by the time I do.........
I've waited years for this feature, please work.
Robert I've noticed and appreciate your refrain from negative editorializing when it comes to DP. Thanks so much. I hope people at MOTU appreciate it also. Like you've said those guys at MOTU are working hard to get things right. Thanks for your work in testing the things many take for granted.Robert Randolph wrote:Please try it yourself if you can! I can only assume that MOTU had this working on their end.Phil O wrote:Ouch! Thanks for the heads up.
It must be something about my system that's messed up somewhow, right? Is anyone else seeing weird issues with it?
I've been more careful in how I phrase things recently for sure.waxman wrote:Robert I've noticed and appreciate your refrain from negative editorializing when it comes to DP. Thanks so much. I hope people at MOTU appreciate it also. Like you've said those guys at MOTU are working hard to get things right. Thanks for your work in testing the things many take for granted.Robert Randolph wrote:Please try it yourself if you can! I can only assume that MOTU had this working on their end.Phil O wrote:Ouch! Thanks for the heads up.
Someone for sure will take something you say the wrong way. Right? There's always room for misinterpretation...Robert Randolph wrote:...so there's no room for misinterpretation.
Ugh. I hate jello.Phil O wrote:Someone for sure will take something you say the wrong way. Right? There's always room for misinterpretation...Robert Randolph wrote:...so there's no room for misinterpretation.
...and Jello.
That's what I was doing. I was getting a delay of about 200 Msec when using an outboard UAD on another Mac. This is supposed to be measured automatically by the new plugin but I get very inconsistent measures so I'm still using manual routing.SMS wrote:How are you guys 'pinging' this?
Intuitively, I would insert the plug on an audio track, assign it to an output, loop that output back to an input, record that input then visually verify the offset between the sent and re-recorded waveforms. Is that what you're doing?
Also please explain the math of how many samples one would expect to see at a given buffer setting.
I never got this working properly. The timing was usually off. I went back to sending a transient and measuring the latency and using AUDelay as an insert to compensate.mrgkeys wrote:is anyone using this successfully? I'm trying to set up a new Template for mixing this year and I'm having scattered results in 9.52. Sometimes it works, sometimes it doesn't. I'm having better luck with mono channels, the stereo ins and out don't seem to pass audio at all. I've tried the Hardware inserts in PT, S1 and Logic, and they're fine. I know my patching is good. Just can't seem to get them to work property in 9.52. Can someone check at NAMM if they are using Bundle Names in DP10?
