Parameter linking between separate plugin instances?
mwilloam
Post by mwilloam »
Say I have 3 vocal tracks and each has its own instance of a compressor(ie motu dynamics), is there a way to link say, the thresholds so adjustments to one adjust all 3? I know similar but not equal alternatives are bussing to an aux group, automation, copy/paste but not the same either for how it would react(aux) or amounts of steps(copy-paste/auto). Just curious if someone has discovered a creative workaround or, would find it useful.
philbrown
Re: Parameter linking between separate plugin instances?
Post by philbrown »
I own a lot of plugs and I'm not aware of any MOTU or 3rd party plugs that have that capability. To answer your last question, I've never seen any need for that capability.
There are plugs that have interconnectivity though– I believe Slate's console plugs can 'talk' to each other for example, but that's not really the same thing you are describing.
Phil O
Post by Phil O »
Melda talks about MIDI controllers controlling any parameter, but it's a feature I've never explored. I don't know if you can control multiple plugins with a single MIDI signal or not. Or if you could use a MIDI track to control a plugin (or multiple plugins)... Just thinking out loud.
BTW, Melda has some pretty good stuff at reasonable prices.
kazuya
Post by kazuya »
Hi,
you can assign a MIDI controller to different plugins at the same time. Just hit MIDI learn at one Plugin and go to console to duplicate the settings. After that you can go to "control assignment" and choose the target track...
Hope that helps... :-)
DP 9.12 // MacPro 8-Core 2,26 // OSX 10.11.6 // 32 GB RAM // UAD-2 // PSP // Sonnox // 828 MK-II // Altiverb 6 // MachFive 2 // iZotope // ...
Excuse my bad english. I´m just a german.
mwilloam
Post by mwilloam »
kazuya wrote:Hi,
Interesting, I just realized that was there. For others:
https://youtu.be/Uyt5SA-KDyI?t=47s
That's a decent workaround albeit not perfect as it(i guess) requires an external controller. Would be nice to be able to control from a MIDI track fader.
I had the idea from working in Machfive/Falcon where you can create macros to do all sorts of stuff. So yeah, I guess it is just a macro.
Appreciate the replies and ideas.
kazuya
Post by kazuya »
If you work in the "console" you can assign a MIDI track. You do not need an external controller.
I try to attach a picture. If it works you see 2 knobs in the console. One is the master. The second one is the slave with values set to negative. The first one is controlled by the MIDI track.
Now i can control 2 Proverbs with just one MIDI track. In this case i can crossfade between a big room and a smaller room on proverb nr.2
/Users/kazuya/Desktop/Console.png
mwilloam
Post by mwilloam »
kazuya wrote:If you work in the "console" you can assign a MIDI track. You do not need an external controller.
Very cool thanks. Sorry I didn't read the details in your last post. So yeah, that should pretty much work! Definitely opens some additional doors for mixing in DP. Thanks again.
kazuya
Post by kazuya »
Your welcome. Also inspired me to think about some "console tricks" :-)
