The Robb Report
- Robb Scott
The Robb Report
V. 9.12.,
2009 Mac Pro, 2.66 mHz 8-core, 16gb RAM
FINALLY Upgraded this beast, and am thus ready to resume bitching and whining. As you might remember (or don't), I keep a text doc open as I work with DP, jotting down any thoughts, gripes, observations, considerations (Christ, I'm turning into Adrian Belew), etc. As per usual, no attempt has been made to proofread for spelling or grammar errors, nor to double-check any question that could've been easily figured out by reading the frickin' manual.
The 1st batch....
Track Window Comments: They no move (wasn’t that the punchline to a really juvenile dirty joke when I was a kid? Ahem...) Anyways, suggest adding an option to show the comments field as a button (the button would change color and/or shape when the field contains some text). The button would open the track’s comment box when pressed...the button’s column would be allowed to be moved and placed like any other column. I do a lot of commenting at the beginning of a project, and this would allow easier access to the field, and allow me to move it the hell out of the way when it’s time to do so. This one’s a little obscure, but hey, I column like I (SMACK! Hey, OK, I’ll quit it, jeez....)
I wanna duplicate an entire Track Folder. Including any sub-folders. I want to do this repeatedly, and with great urgency. Renaming conventions would be a discussion...
When you disable an entire track folder, DP should remember which audio tracks or subfolders were disabled, and then not turn them on when the folder is re-enabled.
I want to specify which track a freeze goes to. You should default to, ummm...where-ever it’s defaulting to now. Just let me choose (in case its default track changes, like the one that just did on me)...
JEEZ THIS THING CRASHES A LOT
(That is, possibly, my fault.....)
Welcome Screen: Put me down as being for this one. Nice idea, well executed...
From the Sequence Editor, I want to dismiss a track from view, close it one-click like a Finder window, as if I’d deselected it in the Track Selector.
(yes, monitor real estate is a problem hereabouts...)...
OK, so I open up Setup/Configure Audio System/Configure Hardware Driver. I don’t change anything, I just wanna check where I left the Buffer size. I cancel. The Audio System reloads anyways, along with every single VI I have open - which is a lot at the beginning of a project. I am sad, and I’m out of coffee. ...
In the Tracks window, I’d like the abiulity to Modifier-DoubClick on a Track label or the Track itself, and open said track in its appropriate Editor, showing only that window.
Y’know what’d be cool? Reverse Repeat. It’d be a check box in the “Repeat” Dialog box - Repeat X number of times, but instead of Repeat Forwards, it’d be Back X number of times. You could stick this one in while you’re finally implementing “Repeat Until”, a request I’ve been bugging you guys about for (now) Two (count ‘em) 2 centuries. More on that one soon...
OK, sometimes I’m freezing a VI track, and I find I’ve selected a tad too much of the track. I can cancel, but then I have to start all over again. What I’d like to do is cancel the freeze, but have the option of keeping what I’ve frozen so far....
While Selecting, I’d like to hold down a modifier key such that, no matter where Snap-To-Grid is set, the selection snaps to whole measures.
Why is it that everytime I quit I get “The Application Digital Performer has quit unexpectedly”? Seems to be saving the Project at quit, but it’s still a bit unsettling (Moe Howard voice: “My Nerves, My Nerves...!”) The Alert Box has a “Send” button, so I hope you’re enjoying the reports...
The 1st batch....
The One True Robb
The One True Robb
Re: The Robb Report
9.12 is overdue for an update. Too flakey for my work. 9.01 seems pretty reliable. Thanks for the report. I agree with most of it. Maybe even all of it.
Re: The Robb Report
By "upgrade, I guess you mean software.Robb Scott wrote:V. 9.12.,
Whenever I see a 2009 running original CPUs, I always like to mention that, for very nominal expense, you can upgrade your 4,1 to a 5,1 12 core 3.33 beast. Willingness to get under the hood is necessary, but the job isn't that tough, especially if you purchase de-lidded CPUs. For more, see this thread:
viewtopic.php?f=4&t=58848&hilit=X5680
Xeon X5680 CPUs now cost about $100 each. Just sayin'.
If monitor real estate blues are impacting your workflow, see this thread:
viewtopic.php?f=26&t=62951&p=537867&hilit=X5680#p537867
- Robb Scott
Re: The Robb Report
Yeah...I've been slogging along in v7.x for too long, finally got around to bringing it up-to-date. I don't do these hideous reports unless I'm commenting on the absolute latest version (and to that end, looks like I gotta look into DP 9.1....)HCMarkus wrote:By "upgrade, I guess you mean software.Robb Scott wrote:V. 9.12.,
Good tips, and thanks....!
The One True Robb
The One True Robb
Re: The Robb Report
In 9.12 you can see the buffer size (and other audio system info) in the transport bar in the consolidated window, and you can actually change them there as easy as changing the project's tempo.
Mac Studio M2 Ultra 128G RAM OSX 14.3, 16" MacBook Pro M1 Max, UA Apollo x6, UA Apollo Twin, UAD-2 Satellite (x2)
Re: The Robb Report
Now I can't remember why I stopped using DP 9.12. Maybe I'll give it another shot to jog my memory or, hopefully, not see any problems.
- Gravity Jim
Re: The Robb Report
You really should, MLC. It runs like a watch on my rig. Maybe you just had a bad install or something.
Jim Bordner
Re: The Robb Report
Could be. Reinstall, kill the plists, blame the victim! LOL Thanks, Jim.
- Robb Scott
Re: The Robb Report
And so you can. There is sometimes a downside to using a software product for. like, forever (My first copy of DP was procured in '94 or so). Stuff gets tossed in that you just don't notice sometimes. Thanks!dinobass wrote:In 9.12 you can see the buffer size (and other audio system info) in the transport bar in the consolidated window, and you can actually change them there as easy as changing the project's tempo.
The One True Robb
The One True Robb
Re: The Robb Report
I agree. it's especially helpful at shows where I get jack squat for setup time. That 30 seconds of File, Open, Browse, Select is time well saved!
MacPro 12core 64GB Ram 4 1TB SSDs motu 828mk3 DP 10.11
