Immediately after upgrading to 9.12 and opening a session there was no sound and no meters moving in HD 192. Restarted DP and things were working again. But it continues to happen. Old or new sessions.
However, if I open a file from the finder it plays fine - default 1&2 of interface.
So, it seems it's something with the 9.12 upgrade.
Reinstalled 9.12 Repaired permissions. No help.
Talke to MOYU but no help. Will try someone else.
Any ideas?
DP loses touch with HD192 after upgrading to 9.12
DP 9.12, OS 10.11.6, mac pro 8 core, 24 gigs ram, Mach Five 3.2, MSI, Superior Drummer, Battery, Reason, Slate Drums, EW Gold
http://www.2ndstprod.com
http://www.dannysguitarshop.tv
Re: DP loses touch with HD192 after upgrading to 9.12
Do you have the latest version of the drivers installed?
Yes - I did that I believe when I went to 9....
Again, I had some other issues with the previous version - couldn't tab correctly in soundbites - fixed in 9.12, but this started immediately after installation of 9.12 (and reinstall didn't help). Thanks.
james, should this be in troubleshooting?
Moved.
It's a thing apparently. I have the same issue with my 2408mk3 on larger projects. No resolution yet. Here's another thread with more info on the issue - including another user with a HD192. viewtopic.php?f=26&t=62446
