I've been using my 828x for some years without main problems. Not a easy product but was working well. Lately I updated to Sierra since in the Motu site they said that the software was compatible with Sierra...but... but...
I experimented some strange problems trying to select the different monitors attached to the main outputs, analog outputs and headphones... I thought that could be a "dirty" OS since there are some years I haven't cleaned... so, I re-installed from scratch Sierra, reinstalled all the Motu drivers..and has been working for some days until now.
The main problem is that the 828x doesn't answer to the "orders" about the outputs! If I select, for example, the Analogs 3-4 in the Default Stereo Output, the sound from iTunes/Safary/Quickmove doesn't go the the output...is going randomly to other outputs.
I tried 12566 things... nothing worked until...surprise, surprise, I changed the Sample Rate to the maximum... 192200 and... works perfectly!!! If I down the the rate... stop sending the signals to the correct place...
I tried with Enabled Core Audio Volume Control, without, ... nothing changes. Also, I found that sometimes, works when I open the Audio MIDI Setup and I select the Speakers to the output I want... but that was not happening before.
I open a ticket in Motu...Jus wondering if somebody has a similar problem...
Regards.
