asio cannot use this motu pci configuration no output
alexg1200
Post by alexg1200 »
Been having a a bad time with this. I install the drivers, then physically install the 424 pci card. If I attempt to switch to motu pci asio in pro tools 12, I get the following message: " asio cannot use this motu pci configuration because no outputs are enabled." I follow the prompts to enable the outputs but the drop down menu I would normally use to enable them is empty. Any ideas? I've tried uninstalling and reinstalling, tried switching ports, tried switching pci slots. Nothing works. The Motu audio console tells me n0 ports are enabled but I have no idea how I can change that.
HD 192 and now 828mk3.
Windows 10
AMD 3.5ghz 8 core Processor 3.5ghz
16gb ram
64bit
I go to the PCI audio control and not able to select and thing or load interface configuration.
Re8et
Re: asio cannot use this motu pci configuration no output
Post by Re8et »
Try to run the audio troubleshoot, first.
If have latest win updates drivers try uninstall them.
see my thread on win updates motu crash, there are my uninstalled updates.
