Reverse Plug In and Reverse Phase not in DP 7.22?
Re: Reverse Plug In and Reverse Phase not in DP 7.22?
Hi! I'm using DP 8.07, and I can't find the reverse plug in anywhere... Where do I find it? Also, can anyone recommend a good sample library for use with DP? I'm looking for both orchestral and industrial sounds. Thanks so much! : )
Reverse is not available as a realtime plugin, it is however still available as a "destructive" process. Open the soundbite window, double-click on the soundbite, select-all or select the portion you want to reverse, then go to the Audio menu and choose Apply Plugin. From there, you can find "Reverse" in the Manufacturer/MOTU list.
For Phase invert, you can choose the Trim plug-in, but the Phase invert is available in the Category/Utility.
If you aren't seeing them in those locations, post back here.
As stubbsonic has pointed out, both Reverse (audio runs backwards) and Invert (audio is 180* out of polarity) are available—as they have been since v.2 or 3? Invert is in a different place but his directions should get you there.
As I recall installing DP8 removed the Reverse destructive plugin from DP7. ...he may be referring to that.
I vaguely recall that as well. It's possible I dragged it in from another install and forgot that I did that.
Just wondering. Is there a way to assign a key command to (apply plug in). It would make workflow quicker. Maybe in D.P. 9?
thanks,
scooter
thanks,
scooter
Macbook Pro OS 10.12.6, 2.6 GHz Intel Core i7, 16 gig memory, Apollo Twin audio interface.
Yes. It's available in the commands window.
Setup>Commands
In the search field type apply and you'll see it.
Setup>Commands
