Can't get audio when selecting.
NealF
Post by NealF »
I used to have it set that whenever I double clicked on an audio file in the sequence window and then selected a portion, I'd get the audio of that selection. For some reason it's no longer doing that.
I know there must be a setting somewhere but I can't find it.
Thanks.
MacPro5,1 6-Core Intel Xeon, Processor Speed: 3.46 GHz
Number of Processors: 1
Total Number of Cores: 6
L2 Cache (per Core): 256 KB
L3 Cache: 12 MB
Memory: 32 GB. Mojave. DP 9 and Apogee Duet.
Tritonemusic
Re: Can't get audio when selecting.
Post by Tritonemusic »
When you double-click, does the soundbite change to a black-and-white look? If it doesn't change, make sure you're using the Pointer Tool. You can't Pop-Edit with the I-Beam Tool. That's all I can think of for now.
NealF
Post by NealF »
Yes. It goes black and white. Then I just drag/select a portion of it. Usually, it just plays that selected bit. Now, nothing.
L3 Cache: 12 MB
Tritonemusic
NealF wrote:Yes. It goes black and white. Then I just drag/select a portion of it. Usually, it just plays that selected bit. Now, nothing.
Okay. I'm taking a wild guess here, but check and see if your main audio output is at the top of the list in the Bundles window. If not, drag it to the top of the list and see what happens.
NealF
Post by NealF »
Looks okay. Must be something else. I recall this happening many years ago. Don't know what the fix was.
L3 Cache: 12 MB
Up in the transport window there is a button with a speaker icon on it. It's right next to the metronome button here. That toggles on Audible Mode.
Tritonemusic
Audible Mode! Totally slipped my mind. Good one, Stubbsonic.
NealF
Post by NealF »
That did it!
Thanks.
L3 Cache: 12 MB
