DP 9 crashing every time during bounce
Hey Folks,
Just checking to see if anyone else has this issue in the latest version of DP9.
Windows 7 64bit
MOTU Audio Express
I have an existing MOTU tech link in play for this issue.
Set up a project with 0 plugins. Master Fader + 1 stereo audio track with some audio in it.
Select a portion of the track and try to bounce it. DP9 fails at the bounce and needs a force quit via the task manager. Every single time. Here's the catch: if I change the driver to the Windows Audio Instead of MOTU ASiO, it will bounce successfully.
Here's the other catch: DP8 on the same system bounces successfully every time. No issues.
Any advice would be helpful. I will report back here with any info I receive on the Tech link.
Thanks.
John
EDIT: please see below for an update to this thread.
Windows 7 64bit
MOTU Audio Express
Thanks.
John
DP 9.5, Windows 10 64bit, i7 7700k @ 4.5 ghz, Asus Maximus Hero IX MOBO, 32Gb Ram, GeForce 750ti Strix edition, Samsung M.2, Be Quiet Case + PSU + CPU Cooler + Fans, a bunch of WD drives.
- terrybritton
- Primary DAW OS: Windows
Re: DP 9 crashing every time during bounce
This is a long-shot, but check your bundles.
I had Melodyne messing up my ability to add a stereo track. So, I am paranoid about bundles now!
Terry
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Thanks for the bundles idea. I had checked this initially, and it isn't a part of the problem.
Also, try disabling VST plugins. PSP's VST plugins, specifically, will crash DP 9.1 every time. AUs are ok but you're on a PC so that isn't an option AFAIK. I'll put $$$ on the fact it's a VST plug in somewhere...
How much $$$ were you discussing, anyway?
No plugins in the project, at all.
Disabled all plugins at the startup of DP9.
Still crashes.
Still crashes.
No $$$. I'm not allowed to bet. 12 step program... LOL Sorry that didn't help. It was/is a reliable crash on my Mac every time.
Thanks for the plugin suggestion. It was a good idea, although this case is different somehow.
- Robert Randolph
If you add a second empty track, does it crash a too?
Yes, it pretty much crashes on bounce in any situation.
After some back and forth with the tech, it is looking like it might have something to do with any project created after the initial project I created in DP9 (which will actually bounce properly, strangely).
I am wondering if all of the project files somehow became corrupted from templates carried over from Dp 8.07.
For anyone that followed this post, I'm putting this thread to bed.
I thought I had figured out the problem, yet was mistaken.
MOTU tech really did try to help, but I am afraid it's beyond us to figure this out.
Couldn't get it to work on my W7 rig. When I build a new DAW for W10, I'm sure it will work just fine.
If the term 'Ghost In The Machine' every applied, it would be here.
Re. the ghost in the machine: I know this is Windows but...
On a Mac, Bounce to Disk crashing is a reliable symptom of a bad stick of RAM. If a certain plug is crashing BTD, eliminate it, of course, but if there's still a problem, RAM is where I look for—and find the culprit.
If you're building a new machine and the ghosts vanish...
RAM is of course, a good idea.
But: DP8 bounces like a champ. My other main DAW bounces like a champ.
I think there is something specific to my DP9 installation that has gone south and can't be fixed (or I am not willing to continue on this miserable journey to find out what the solution is when my other DAW is my main software and DP8 works well).
Funny that bouncing in DP9 is literally the only feature I didn't test before purchase.
Thanks for the suggestions, folks.
Happy Non-Specific Holiday Celebration to all!
Hi John:
I was having the same problem. DP 9.12 on a new Windows 10 machine. Simple bounce to video was crashing DP every time. MOTU tech support suggested installing DP 8 and trying it. That worked - my test file bounced just fine. (albeit very slowly). Then I went back to DP 9.12 and tried the test file again, and now DP 9 bounced without crashing. Weird. The only change on the machine was a Windows auto-update, and iTunes for Windows update and installing DP8. Somehow that combination made everything work.
About the slow bounce time: I set up a test file with two stereo audio tracks and a .mp4 video file. I bounced an 11-second section on my old mac 2008 running DP 8 and it bounced to a .mov file in 5 seconds. I did the exact same bounce on my Windows 10 machine and it bounced to a .mp4 file in 1 minute 20 seconds. I changed from the ASIO driver to the Windows driver and that lowered the bounce time to 1:04. Anyone know if this is just a Windows thing?
Also, there's no Quicktime Export Options dialog box after I OK the bounce dialog box. Is the inability to include film scoring events another Windows thing?
Hi swander,
I'm not sure it's exactly the same event we are describing.
I wasn't dealing with video whatsoever in these projects.
And DP9 would render odd lengths of corrupted audio and then would hang.
On my generic Acer Windows 10 machine (not a music rig), I had an active demo of DP9 that worked flawlessly. (Although I did not test your video bouncing)
I use two DAWS, and DP compliments the other one nicely. Once I build a new W10 rig I'm confident that things will work just fine.
Just an update for this thread: I built a new W10 rig and am using DP 9.5. I’ve battle tested DP for a few weeks and it has worked flawlessly so far.
