Dp9 crashes when switching to next chunk
sirvigalot
Post by sirvigalot »
Anybody have a fix for this when using cue next chunk dp9 stops freezes and gives me the spinning wheel of hate until I force quit....
dix
Re: Dp9 crashes when switching to next chunk
Post by dix »
Are you seeing this with all Chunks or just ones in a specific project? If the latter, have you tried Loading the Chunks into a new Sequence?
sirvigalot
I've loaded from another project as well as rebuilt the project using new stems but I've noticed once I deselect cue next chunk and stop with space bar then select the chunk using my MIDI controller it doesn't crash.....
sirvigalot
sirvigalot wrote:I've loaded from another project as well as rebuilt the project using new stems but I've noticed once I deselect cue next chunk and stop with space bar then select the chunk using my MIDI controller it doesn't crash.....
sirvigalot
Guitar Gaz
Post by Guitar Gaz »
I have had a few occasions when I have switched chunks and then the editing window seems to be disconnected - such as the TO which then does not show that chunk as being loaded - you then have to switch chunks back and forth till it catches up. I don't know if this is a Window Set issue or just a bug.
Gary Shepherd
____________
