New macs - new system upgrade questions
DougieFresh
Post by DougieFresh »
By now, I assume most mac users have seen the 2016 MBP release. Without getting into the state of Apple and its latest offerings (or lack thereof), I need to bite this year and replace an early ’08 MBP still running OS 10.6.8 and DP 7.??. Some brief questions regarding upgrading the studio ecosystem, as it’s been a really long time since my last major upgrade. I consider myself a low to moderate CPU and audio/MIDI track count user for what it’s worth.
Am I right in still assuming the core practice that I should be recording to an external drive in 2016? If so, am I good with a disc-based USB external drive – or should I consider SSD despite cost and size restrictions for a drive that doesn’t spin. Performance differences between SSD & disc? Have always used a separate drive for recording, going back to my first system in 1993 with Mac II CI and 80 MB external drive. Always thought it was a practice mostly used to keep the load off the internal bus of the computer. Not sure if that’s accurate or applicable to today’s computers.
Also wondering about the state of my 828mkII (still running fine) and if this is the point in time to upgrade to something like an Ultralite MK-4. My big concern with the 828 is reliability in connecting/adapting Firewire 400 to USB-C. I’m sure the I/Os have improved on MOTUs interfaces over the course of a decade or more. Could still use the 828 with the 2008 MBP as a secondary system.
With DP9, I’ll be using Mach 5 III, all Spectrasonics instruments (excluding Keyscape), Kontakt, and a few other VIs.
It’s been so long since I’ve had to replace various components at once - trying to be smart about this. Grateful for any thoughts & thanks!
Doug
MacBook Pro touch bar, Late 2016; 2.7 GHz i7; 16GB RAM; 500 GB SSD / MOTU 828 mkII / DP 9.12; Mach 5 III / Omnisphere, Stylus RMX, Trillian / Kontact 5 / NI Komplete 11
Re: New macs - new system upgrade questions
No unless you don't have the storage space.
It isn't—hasn't been since the SATA bus was introduced with the G5 in 2002.
The Samsung 850 EVO 2T has a street price of less than $600. Put it in an external TB, USB3 or USBC housing.
Night and Day—many, many threads on this.
Should still through the Apple Thunderbolt-FW adapter. The latest MBP supports Thunderbolt on all 4 ports.
You will have to upgrade to DP 9. Although DP 7.24 can run under OS 10.12 Sierra, there is no way to install a working copy. If you get an older Mac that runs Yosemite, DP 7.4 will install as long as you have a CD drive available to authorize.
The only reason to use an HHD anymore is Time Machine. Get an Apple Time Capsule and set up a wireless connection. That way, when you are in your studio, Time Machine will run automatically in the background. The current tower version supports 802.11ac wireless—faster than gigabyte ethernet (really).
http://www.apple.com/search/time-capsule?src=alp
If you buy one at the same time as your MBP, you can include it in AppleCare at no additional charge.
Regarding AppleCare, it gives you three years of call-in support. Sometimes, during updates, having that is a real lifesaver (besides the extension of the hardware warranty to three years).
When you get your new machine, use Time Machine or Migration Assistant to pull your files off the old Mac.
If you must copy and move, compress (zip, archive) your old files first. This will save you a lot of grief, especially with your DP files. Expanding them on the new system grants privileges and permissions automatically.
DougieFresh
Mike, thank you so much. Really appreciate your time and knowledge with my questions. Have been wanting to upgrade to DP9 for a while, but have been waiting for a new MBP to run it. Will try my 828 with adapter before replacing. Thanks again!
No problem. Mine was one of the very last which means it is 9 years old—still working fine, BTW. These don't last forever and develop screen, FW and power supply problems judging by many posts over the years.
So, it's not a bad idea to budget for a replacement but, till then, you should be good.
My 828mkII is still going strong. I also have a backup, purchased barely used for $200, ready to replace it if and when necessary.
kwiz
Post by kwiz »
Great family and friends!
F. Douglas
THAT is funny!!!
frankf
Post by frankf »
Loved it! ROFL for sure.
Frank Ferrucci
http://www.ferruccimusic.com
The Mac version of Robin Williams describing golf:
https://www.youtube.com/watch?v=fui7yvebIdk
DougieFresh
Kwiz, that is hilarious. Still laughing. Looks like I'll need to dongle up then. :lol:
kwiz
Post by kwiz »
:lol: :lol: Exactly!
F. Douglas
kwiz
Post by kwiz »
DougieFresh wrote:Kwiz, that is hilarious. Still laughing. Looks like I'll need to dongle up then. :lol:
:lol: :lol: Plus one of these if you use a second monitor with all the trimmings.
https://eshop.macsales.com/item/OWC/TB2DOCK12T1/
F. Douglas
