AlphaTrack lives on in El Cap!!
Re: AlphaTrack lives on in El Cap!!
Fantastic!
Frank Ferrucci
http://www.ferruccimusic.com
Tranzport now works on sierra with the update...
Thanx James! Done! So nice to have my Tranzport back!!
Sent from my XT1030 using Tapatalk
|l| OS X 10.8.5 ML |l| 2.8 GHz MacBook Pro-8GB RAM |l| DP 9.02 |l| VE Pro 5 |l|Motu MTP AV-#2 MIDI Express USB-#2 2408 Mk II |l| #2 Mackie 400f's |l| Peak Pro 7 |l| Waves 9.x |l| CLA Classic Compressors |l| MPX Master Tape |l| Vocal Rider |l| iZotope Stutter Edit |l| Omnisphere 2 |l| Mach5 2 |l| Sample Tank 2 |l| Sonik Synth 2 |l| Stylus RMX |l| VirHarmonic |l| Albion I |l| VE Pro 5 |l| Superior Drummer 2 |l| EZ Drummer |l| Drumcore 2.5 |l| Garritan Personal Orchestra |l| Many hardware synths.
In my initial post about the new installers I said I "disabled SIP" before installing. I meant I "ENABLED SIP" before installing. I edited my post. One of the main features of the new installer (besides that it actually runs on newer MacOS versions) is that SIP does not need to be disabled!
I've lost functionality under Mac OS X 10.11.6 El Capitan
Alphatrack Manager is in the menubar, and it's assignable in Pro Tools peripherals menu, but the hardware does not respond. Pretty sure HW is OK, it was working fine til recent OS X update.
Any ideas??
Any ideas??
madtheory wrote:I've lost functionality under Mac OS X 10.11.6 El CapitanAlphatrack Manager is in the menubar, and it's assignable in Pro Tools peripherals menu, but the hardware does not respond. Pretty sure HW is OK, it was working fine til recent OS X update.
Any ideas??
Whoa!!
I'm about to upgrade from Mavericks to El Capitan. BUT, does this mean that even using this new updated installer, Alpha Track will not work in El Capitan?
Is anybody able to use Alpha Track in El Capitan? Is anybody else having the problem madtheory reports in his post quoted above?
Lastly, I already previously bought the 64 bit update for Alpha Track and it is installed. So, if I update from Mavericks to El Capitan, do I need this new $35 installer for Alpha Track that lets you install in El Capitan with SIP enabled, since I've already got the prior 64 bit update for Alpha Track installed? i.e., is this new updated $35 installer only needed for installing?
iMac 3.0 GHz, 8 GHz ram, OS 10.6.4, MOTU 828 Mk II, MOTU MIDI Express-XT (x2), KRK Rokit 6's, Novation Remote Zero SL, Radikal SAC-2k, Triton rack maxed out, Matrix 1000, Handsonic HPD-15 drum pads, tons 'o VI's.....
I've been running AlphaTrack over El Cap ever since the new driver became available. It's always been solid for me.
I'll be doing a clean install of Sierra in a couple weeks, so I will soon be able to report on how it works there.
It works for me under Sierra, but I must occasionally unplug and replug the USB connection to get it going when I start up.
I still have that issue. Also, if I want to nitpick, there's still an issue where parameter values on the AlphaTrack display don't update as you're turning a knob. For example, when you grab a rotary encoder and start to turn it a bar graph display appears with a numeric value to the right. This remains static, however it is still sending the correct controller info. One of these days I'll email the programmer and see if he can tweak it. I know he may have fixed this once in the past on an earlier version.HCMarkus wrote:It works for me under Sierra, but I must occasionally unplug and replug the USB connection to get it going when I start up.
