cannot drag Pitch Blocks?
williemyers
Post by williemyers »
this one's wierd....
I have a project where I need to manually pitch-correct some lead vocals.
I did the first tune like a breeze....setup a chunk with a Mono Vox track, drug in the Mono .wav, opened it and drug the Pitch Blocks around, as necessary. Sounded fine. Bounced it and prepared to move on to the next tune...
Saved it, copied that chunk, deleted the old VOX, drug in a new Mono .wav, opened it and saw all of the Pitch Blocks - BUT - (a.) I can't select the Blocks - just the squiggly stuff - and (b.) when I grab a Block, it will not be drugged! (nor will I!)
What am I missin' here?
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
williemyers
Re: cannot drag Pitch Blocks?
not to worry - a restart fixed it.....
~me
tommymandel
Post by tommymandel »
Glad the restart fixed it willie. Sometimes I have to zoom in to a certain magnification to be able to work with the pitch blocks in the Sequence Editor window.
