All configurations lost in OS update
I recently updated the Mac OS to 10.11.6, from 10.8 . . . in doing so, all of my MIDI configurations are lost. I have 2 outboard synths that were accessible via DP, now, everything goes to default locations.
MOTU tech support told me I could transfer these setups from saved versions of the old OS, but the files they told me to look for are not in the locations where they said they would be.
I had installed DP9 before I installed the new OS and it was working fine... how can I get things back to working as they were?
Re: All configurations lost in OS update
a) You can try disabling SIP temporarily. If your settings reappear, they are in the System where OS 10.11 will not allow them to be accessed. You will need to move them into the proper directory. Reenable SIP when done.
http://www.imore.com/el-capitan-system- ... lware-away
b) Do you have a Time Machine backup? If so, enter Time Machine and scroll back to a date and time when the old OS was active, You must know the old path to the settings. Find the folder, copy the settings and paste into the correct directory.
c) There is something that worked fine in OS 10.8.x and no longer works in 10.11. If so, neither (a) or (b) will work either.
Thanks for the response, Mike, but that's just it, I don't know what files I need to find and move. MOTU tech support emailed me a path to what were supposed to be those files, but what he said to look for isn't there, either in the new OS or on the Time Machine backup, it's either the wrong path or the wrong files. Do we know which files it is that dictates the way the MIDI system is set up in DP, and where they are?
b)" Do you have a Time Machine backup? If so, enter Time Machine and scroll back to a date and time when the old OS was active, You must know the old path to the settings. Find the folder, copy the settings and paste into the correct directory."
DP never puts any files into /System, and never has in the past.mikehalloran wrote:a) You can try disabling SIP temporarily. If your settings reappear, they are in the System where OS 10.11 will not allow them to be accessed.
If MOTU support mailed you the names of the files, you can try to find them on your current hard disk. In Finder, use cmd-f to open a search window, in the pop-up menu, select 'Other' and tick 'system files' and 'file visibility', and select to search both visible and invisible files, with system files included. ('System files' in this context means not only files in /System, but also files in /Library and other locations.)MidiVeg wrote:Do we know which files it is that dictates the way the MIDI system is set up in DP, and where they are?
What's the path that MOTU support suggested?
No but other programs, utilities and VIs did.stratology wrote:DP never puts any files into /System, and never has in the past.mikehalloran wrote:a) You can try disabling SIP temporarily. If your settings reappear, they are in the System where OS 10.11 will not allow them to be accessed.
mikehalloran wrote: No but other programs, utilities and VIs did.
...which have nothing whatsoever to do with to OP's loss of DP configurations.
Apologies if I'm stating the obvious, but make sure you don't confuse similar looking file paths, like /Library/Audio/MIDI Configurations and ~/Library/Audio/MIDI Configurations...MidiVeg wrote: the files they told me to look for are not in the locations where they said they would be.
Thanks everyone for your input. Here is exactly what was sent to me by MOTU. I can get to the referenced "MIDI Configurations" folder in 10.11... It contains a file called
Default.mcfg'. However, there is no corresponding folder in my OS 10.8 Time Machine back up.
Find your configuration file on your OSX 10.8 system. This file will be located here: Users/***your username**/Library/Audio/MIDI Configurations
NOTE! That on any OS version higher than 10.7, the User library is hidden. To access this library folder open any Finder window, choose the Go Menu from the top of the screen and hold down the option key. You will see the Library item appear. Click it and navigate to Audio, MIDI Configurations.
2. Once you have located the MIDI Configuration file, save this file to an external drive.
3. In your new 10.11 system, navigate to your User LIbrary (again you will need to use the Go Menu with the option key pressed down). Any copy the old configuration file to the MIDI Configurations folder.
