DP 9.12 out now.
- Gravity Jim
DP 9.12 out now.
Jim Bordner
Re: DP 9.12 out now.
Just getting ready to post. Downloading now. Fingers crossed!!!
Sent from my XT1030 using Tapatalk
|l| OS X 10.8.5 ML |l| 2.8 GHz MacBook Pro-8GB RAM |l| DP 9.02 |l| VE Pro 5 |l|Motu MTP AV-#2 MIDI Express USB-#2 2408 Mk II |l| #2 Mackie 400f's |l| Peak Pro 7 |l| Waves 9.x |l| CLA Classic Compressors |l| MPX Master Tape |l| Vocal Rider |l| iZotope Stutter Edit |l| Omnisphere 2 |l| Mach5 2 |l| Sample Tank 2 |l| Sonik Synth 2 |l| Stylus RMX |l| VirHarmonic |l| Albion I |l| VE Pro 5 |l| Superior Drummer 2 |l| EZ Drummer |l| Drumcore 2.5 |l| Garritan Personal Orchestra |l| Many hardware synths.
The Read Me:
Complete DP9 documentation
You can find complete DP9 documentation (PDF files) on the DP9 installer disc, and you can also access them directly from Digital Performer's Help menu. Table of Contents entries, index entries, and cross references are live links that will jump to their destinations. In some cases, you may need to click directly on the page number (rather than the heading).
Changes and new features
For a comprehensive list of new features, please refer to New Features in DP, available in Digital Performer's Help menu.
Enhancements introduced in version 9.1.2
Version 9.1.2 provides many improvements, optimizations, and refinements. Here are just a few highlights:
• Fixed a bounce to disk crash caused by an issue involving non-active VST effects.
• Fixed a problem where audio would sound choppy after inserting a post-fader effect. • Fixed a crash that could occur if a clipping window was closed while one of its clippings was being auditioned.
• Fixed a crash involving Melodyne.
• Fixed an issue where project VIs would not work correctly when selected as MIDI metronome.
• Optimized code that could impact opening projects with a large number of tracks.
• Fixed an issue where the Ivory Synthogy would hesitate and glitch when beginning playback in pre-gen mode.
• Fixed an issue where recording MIDI data into a track with sustain CC could clear the live state of the sustain pedal.
• Fixed an issue where overdubbing notes in a MIDI track would halt sounding notes already on that track.
• Fixed a case where track sysex data could cause a crash during playback.
I still have the same problems with pre gen and there were spikes in processing with a buffer setting of 1024.... my drum tracks are not lining up.... back to DP 9.02.
9.12
- Robert Randolph
Looks like I got some work to do on the issue list. That's fantastic news!
edit: Nothing in the notes about performance fixes or pre-gen stuff? I hope that's just an oversight in the notes.
Repaired permmissions...
Group differs on "Library/Audio/Plug-Ins/MAS", should be 0, group is 80.
Permissions differ on "Library/Audio/Plug-Ins/MAS", should be drwxr-xr-x , they are drwxrwxr-x .
Repaired "Library/Audio/Plug-Ins/MAS".
User differs on "private/var/db/displaypolicyd", should be 0, user is 244.
Group differs on "private/var/db/displaypolicyd", should be 0, group is 244.
Repaired "private/var/db/displaypolicyd"
Still no splash screen...
Same stuff plus a load of Safari permissions. Apparently the displaypolicyd error will come back on restart and can be ignored.MIDI Life Crisis wrote:Repaired permmissions...
Not coming within a mile of this update till I hear that all the playback/pre-gen/pops and clicks on merging and BTD/audio dropouts while editing bugs are gone.
For everyone or for some? As always there's some YMMV going on.amplidood wrote:Not coming within a mile of this update till I hear that all the playback/pre-gen/pops and clicks on merging and BTD/audio dropouts while editing bugs are gone.
- kassonica
Ooh hopefully this will have the issues sorted and I can install it at the studio
Working great here with Raven. SusPedal works fixed.
waxman
- terrybritton
- Primary DAW OS: Windows
Well, this time I am showing I am learning from you masters and I've renamed the (Windows) DP9 folders in Program Files (x86) and Program Files from "Digital Performer 9.1" to "Digital Performer 9.1.0" so it doesn't erase the old version in case I have to go back. I promptly named my newly installed folders "Digital Performer 9.1.2"
I'm not certain this is also possible with Mac installations, though.
Terry
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
- corbo-billy
It's possible with an Apple computer .terrybritton wrote:I'm not certain this is also possible with Mac installations, though.
Otherwise: does anyone happens to work fine with the new Hardware Insert plug-in ? Here, there I still can't, inserted or not in Aux track .
