DP 9.1 is here
waxman
Re: DP 9.1 is here
Post by waxman »
I will bet anybody on M-nation a thousand bucks it won't be called 9.11...
For those who have ears to hear... "the fix is in." Any day now sustain pedals of the world will be doing the 2 step.
waxman
Re: DP 9.1 is here
9.1.1 or even a new build of 9.1. Wouldn't be the first time.
waxman
Re: DP 9.1 is here
Post by waxman »
Ok it did not happen yesterday... I day it happens before Labor day weekend starts at 6pm EST. So if MOTU takes off Friday it will be Thursday night... Sept. 1, 6pm EST.
Any guesses?
Add to known fixes or wanted fixes.
Pedal sustain (fixed)
waxman
dix
Re: DP 9.1 is here
Post by dix »
waxman wrote:I will bet anybody on M-nation a thousand bucks it won't be called 9.11...
Nailed it!
waxman
Re: DP 9.1 is here
Post by waxman »
The tech let me know last week it would be out quick... I thought it might be last Friday. But they put it out yesterday and everyone at MOTU got out of Dodge. They are doing a 5 day labor day weekend. Some companies are great. MOTU is one of them...
waxman
crescentoon55
Re: DP 9.1 is here
Post by crescentoon55 »
Once I isolated the 2 plugins that were giving me trouble, there were no more problems ... bravo to the coders!! :D
waxman
Re: DP 9.1 is here
Post by waxman »
crescentoon55 wrote:Once I isolated the 2 plugins that were giving me trouble, there were no more problems ... bravo to the coders!! :D
what were the two plugs?
waxman
MonoPoly307
Re: DP 9.1 is here
Post by MonoPoly307 »
MIDI Life Crisis wrote:Latency is nearly non-existent now. So small at 512.
Wow! Are you saying that even if you're running a buffer of 512 samples, you can still play virtual instruments with hardly any latency? (Or run audio sources through effect plug-ins, with the same result?).
If so, that's pretty amazing!
In my experience, as a Logic user, I've needed to use either a sample buffer of 32 or 64 samples for instruments to be really playable, and at 128 samples the latency has been borderline (ok for piano, unusable for a drummer using V-drums through BFD for example).
Anyway - I would love to have confirmation that even at 512 samples, latency is not a problem!
Cheers
Mike
Re: DP 9.1 is here
I can track at 512 for sure. My desktop controller is hooked into USB and my full 88 note kbd is plugged into a MOTU Track 16. I don't know if thetas a factor or my machine is fast (or my brain and fingers are compensating) but I have sometimes forgotten to switch to a high buffer for editing. It also depends on what you're tracking in terms of speed etc. I may well be compensating for latency "instinctively" but it hasn't been an issue for me in a very long time.
Cheers
Mike
MonoPoly307
Re: DP 9.1 is here
Wow! That's pretty incredible performance. At 512, I can absolutely guarantee that with Logic Pro, there's no way I could track any kind of part. Even slow pads wouldn't really be viable with that kind of delay, let alone percussion or piano parts, etc.
It sounds like DP9 really does deliver far low latency at high buffers, which is pretty exciting for someone like me who is thinking about moving.
I've noticed that there are varying accounts in this thread, though - it seems that a test has shown that the new latency in DP is the same as other DAWs (Cubase, Logic), but just reports a different figure. Others are saying that the real-world experience of DP 9.1 is amazing, and even that drummers using V-Drums are finding instruments like BFD to be much more responsive under DP than Cubase or Logic.
I'm going to download the demo for DP in the next few days. I'm looking forward to seeing what my experience is, and in light of some recent issues with Logic, feeling hopeful that it might be time to move.
Cheers
Mike
MIDI Life Crisis wrote:I can track at 512 for sure. My desktop controller is hooked into USB and my full 88 note kbd is plugged into a MOTU Track 16. I don't know if thetas a factor or my machine is fast (or my brain and fingers are compensating) but I have sometimes forgotten to switch to a high buffer for editing. It also depends on what you're tracking in terms of speed etc. I may well be compensating for latency "instinctively" but it hasn't been an issue for me in a very long time.
Cheers
Mike
Re: DP 9.1 is here
Yeloop, what is your machine, configuration, OS, and RAM amount
MonoPoly307
Re: DP 9.1 is here
MIDI Life Crisis wrote:Yeloop, what is your machine, configuration, OS, and RAM amount
Hey MLC,
I'm using a MacBook Pro late 2015, it has a (from memory) 2.8GHz i7 processor, it's up to date with the most recent version of MacOS, and it has 16GB of 1600MHz RAM.
Cheers,
Mike
Re: DP 9.1 is here
Thanks. Should be more than capable.
MonoPoly307
Re: DP 9.1 is here
MIDI Life Crisis wrote:Thanks. Should be more than capable.
I would have thought so, yes. I'll set up the demo version and see how I go.
Thanks for your advice on this one!
Cheers,
Mike
terrybritton
Re: DP 9.1 is here
Post by terrybritton »
toodamnhip wrote:
bayswater wrote: Note, the section on pre-gen suggests adjusting Prime Milliseconds settings to fine tune VIs and plugsins
Are we supposed to just “guess” at this or is there some sort of hint as to which way to adjust the numbers in a given problematic scenario? Not a fan of just “moving numbers around” without knowledge of how or why.
Travis at MOTU just told me that the "magic number" seems to be to change it from a setting of 128 to 500.
Terry
MOTU 828 mk3 hybrid
