Optimizing usage of multiple cores in DP
- waterstrum
I'm running a multi-core Mac Pro, running DP 8 to 9.1.
What is the best way to distribute the CPU load over the cores?
Often, projects will go in to the red when I go to lower latencies, but the Mac activity monitor shows very low CPU use.
It looks like I should have tons of headroom, but audio clipping and the red is blinking.
Some of the cores are lazy and not even being used.
Is there a way to help DP distribute the load?
All is well
Re: Optimizing usage of multiple cores in DP
Yes, but I forget the details. Magic Dave has posted on this subject, I would do a search on his posts.
- buzzsmith
I'd like to know, too. I am using more plugins lately than "normal" and do get the occasional spike using DP 9.01.
I do remember that, if using Kontakt, it's better to use multiple instances as opposed to loading just one with multiple instruments as that somehow forces a spread amongst the cores.
Buzzy
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Large and heavily scripted VI instruments should be in their own instance in f the VI, not shared. For every such VI instantiation there should be a separate faded in the mixed. This allows DP to access a separate core for each.
My impression about the CPU performance meter provided by MOTU is that is a peak reading meter, and the Apple version is average reading.
Once DP9.1 is fully sorted, it should be the answer to overworked CPUs for many.
- Robert Randolph
I've asked NI this directly and their response was the opposite. To use as few instances of Kontakt as possible since it handles multi-threaded operations more efficiently on its own. Now... which DAW they are comparing to I don't know. Logic for instance behaves better with 1 instance per instrument no matter what. Maybe DP is similar?MIDI Life Crisis wrote:Large and heavily scripted VI instruments should be in their own instance in f the VI, not shared. For every such VI instantiation there should be a separate faded in the mixed. This allows DP to access a separate core for each.
I would suspect for other sample players this is highly dependent on the underlying architecture. I know that ARIA based instruments should be spread out across instances as much as possible for instance.
Single instance definitely saves on RAM usage compared to multiple though.
I'd be curious what the results are if someone tested this though. The question gets asked a lot on other DAW forums.
Well that's how MagicD tells it and, in fact, it can and does reduce the processor load on my system substantially. In a non multi-core setting it would, of course, not make any difference at all. Other than that, you are correct.Robert Randolph wrote: I've asked NI this directly and their response was the opposite.
I assume you can deduce your answer to this from my earlier post.Robert Randolph wrote: I'd be curious what the results are if someone tested this though. The question gets asked a lot on other DAW forums.
Just in case you missed it...
viewtopic.php?p=530749#p530749
- toodamnhip
I didn’t understand this sentence, can you please re-state?..ThanksMIDI Life Crisis wrote:For every such VI instantiation there should be a separate ((((faded)))????? in the (((((mixed))))???. This allows DP to access a separate core for each.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- Guitar Gaz
He means fader in the mixer - auto correct error.toodamnhip wrote:I didn’t understand this sentence, can you please re-state?..ThanksMIDI Life Crisis wrote:For every such VI instantiation there should be a separate ((((faded)))????? in the (((((mixed))))???. This allows DP to access a separate core for each.
Gary Shepherd
____________
____________
