DP 9.1 - Mixing Board comes to front after hiding DP
Basstrup
Re: DP 9.1 - Mixing Board comes to front after hiding DP
Post by Basstrup »
Command H to hide, command tab to re engage. Mixer stays behind. Tried Command H and Command Tab to bring another app in front, then Command tab to bring DP in front. Mixer still stays behind.
Analog is great... We got both WOW and Flutter - what's your bias?
MOTU: DP9 - 2 x MachV - 2 x MX4 - 2 x 1296 - 2 x 896HD - 1 x UltraLite AVB - 1 x MOTU Monitor 8 - 1 x 24i - 3 x MTP AV | UA Apollo Quad | UA Arrow | SSL 2+ || Digi 002Rack | Mackie control + expanders | UAD-2 PCIe card | 2 x Mac Pro | Mac Mini Late 2018 | OS X 10.14.6
Post by Shooshie »
So far, the mixer is behaving normally here. I'll let you know if it changes. I'm still assessing things in DP, and while I'm not ready to report on things, I believe there will be things to report.
labman
Post by labman »
Perhaps its an OS X version thing, since cmd H is global hide for OS X???
Babz
Post by Babz »
Robert Randolph wrote:Man, I just can't seem to make this happen.
I'm following all your posts and this seems really odd. :surrender:
If you have any other tips, I'm totally willing to try it out here.
It does seem to be only me... :?: :roll: :smash: :?: :?:
It's a minor inconvenience, but I can't stand little unsolved baffling mysteries like this. Since I can't think of anything else to try...
Robert, would you be willing to try with one of my DP files, if I sent it to you?
If so, send me a PM. I can't seem to figure out how to initiate a PM to someone....
Best,
Babz
Tomas E
Post by Tomas E »
Babz wrote:OK, this may not be a major bug, but it is something that is different in DP 9.1.
I use the Consolidated Window but keep the Mixer in a separate window. If I have the mixer behind the CW then hide DP (Command-H) and go to the Finder, when I come back to DP, the Mixer has moved to the front of the CW. (Arrgh!!! :evil: ) I then have to do the extra step of clicking on the CW to bring it to the front.
I did not have to do this in earlier DP. MOTU, please confirm and fix.
Best,
Babz
I've had that behaviour before. I can be as far back as DP8 or even DP7. I think I contacted MOTU about it, but if I remember correctly they just made my TechLink "in progress" and eventually deleted it. Since you have it but I don't it might be something else than DP itself that generates it.
I must make a correction. When I hid DP everything BUT the mixing window was hidden. That is I saw the mixing window and only the mixing window after hiding DP. But it's still a mixing window issue.
Babz
Post by Babz »
OK, it turns out the key to this issue involves the fact that I also work with the channel strip as a separate window, outside the CW. Thanks to Robert Randolph for testing with one of my project files and helping to get to the bottom of this. I will open a tech link on this.
Best,
Babz
