Seems like when I'm away from DP for a while, I come back and something's changed that I didn't do.
Anyway, none of my external MIDI instruments are showing up. In the audio MIDI set up window Micro Lite is there but grayed.
Double clicking does nothing but bring up the window. Device online is not checked.
The micro lite is blinking when I play my controller keyboard.
Any ideas?
Micro Lite grayed out in AUDIO MIDI Setup
MacPro5,1 6-Core Intel Xeon, Processor Speed: 3.46 GHz
Number of Processors: 1
Total Number of Cores: 6
L2 Cache (per Core): 256 KB
L3 Cache: 12 MB
Memory: 32 GB. Mojave. DP 9 and Apogee Duet.
L3 Cache: 12 MB
Re: Micro Lite grayed out in AUDIO MIDI Setup
Are you using the latest software update? Mine used to go gray a lot... usually I would have to unplug and re-plug the USB line. Its been working with the latest updates but now I have problems with my MIDI timepiece av showing up gray.
I believe I've got the latest DP and the latest drivers.
I deleted it from the Audio MIDI Setup and remade it again.
Now it shows up solid but all the channel connectors are gone and I can't hook anything up to it.
L3 Cache: 12 MB
L3 Cache: 12 MB
