Either 9.02 or latest audio-midi drivers BREAK VE Pro Sync
toodamnhip
Post by toodamnhip »
I updated to the latest motu audio and MIDI drivers today, (V 1.6 68717) ,and VE Pro no longer syncs with DP when VE 's buffers are set above "none”.
Can anyone confirm this?
The system was working perfectly before the install so it has to be the new drivers. I then re installed the OLD drivers and VE Pro is still not working right with buffers above “none” bing out of sync.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
Killahurts
Re: MOTU’s latest audio or MIDI drivers BREAK VE Pro Sync
Post by Killahurts »
Hey 2DH, are you running VEP on the same machine as DP?
toodamnhip
Killahurts wrote:Hey 2DH, are you running VEP on the same machine as DP?
Yes.
I am now uncertain whether or not it was the new driver updates or if it was the 9.02 update itself. Either way, Ve pro is now broken and wasn't before
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Killahurts
Yes.
Maybe you could reinstall VEP. They have a new version that came out just a few days ago.. might fix it?
I have the newest 9.02 DP, and the newest version of VEP appears to be working fine.. sorry, I'm not willing to install the new MOTU drivers to find out if that's what it is.. :wink:
toodamnhip
Killahurts wrote:
Yes.
The issue occurred in both versions of VE Pro, the newest and the one before.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Killahurts
Re: Either 9.02 or latest audio-midi drivers BREAK VE Pro Sy
Guess that leaves the drivers for you then. Does the driver have an uninstall? It may be that the only way to install the old drivers is to wipe out ALL the driver software, then start clean.
toodamnhip
Killahurts wrote:Guess that leaves the drivers for you then. Does the driver have an uninstall? It may be that the only way to install the old drivers is to wipe out ALL the driver software, then start clean.
I don’t know if there is an un install.
I have posted at Vienna and will put up a tech link at MOTU.
Last tech link was never responded to.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
