MIDI controller setting help...
Topo
Post by Topo »
I am trying to figure out what is resetting my virtual instruments to full volume when I start and stop playback on a sequence. I have not created any volume automation...simply recording a MIDI performance from a controller keyboard that is only sending on/off and sustain values. I'll go to the controls of the VI, and adjust the volume down, but it jumps to full soon as I start playback.
i7 2.93ghz iMac SSD & 16gb•DP7.2/9•StudioLive1642•Joe Meek 3Q•ADK Humburg T-67•ADK Vienna•Rode NT2•Taylor GS Koa limited•'71 Gibson Hummingbird•Fender Strat Plus w/lace sensors•Fender P bass•JBL 2325's•MOTU microlite•Tascam DAT•Alesis QS8•Yamaha U3•Ravenscroft 275 VI•Nord Piano•Specialized Stumpjumper Elite
Kurt Cowling
Re: MIDI controller setting help...
Post by Kurt Cowling »
Set the volume using DP's mixing board faders instead. Those values are being sent whenever you push play.
DP 11.34 , 2021 MacBook Pro M1-Max, 2017 iMac Retina 5K 27-inch, Omnisphere, Trilian, Stylus RMX, EZ Drummer 2, Falcon, Real Guitar, Sample Modeling brass. Audio Modeling reeds, strings, Kontakt 6, Flux Pure Limiter 3, PSP Vintage Warmer, PSP MixPack, PSP StereoPack, PSP Impressor, Altiverb 7, Izotope RX10 Standard, Yamaha S-90ES, Yamaha MOXF-8, Yamaha MX60, Sibelius subscription, Adobe CC and Motion 5.
Killahurts
Post by Killahurts »
Happens here too. In another thread, the solution offered was to turn MIDI event chasing off, which worked, but I need event chasing :wink:
In my case, it's not every VI, only a few.. Omnisphere and Arturia come to mind..
Topo
Post by Topo »
That does it...thanks
Kurt Cowling wrote:Set the volume using DP's mixing board faders instead. Those values are being sent whenever you push play.
Kontakt has a setting in INSTRUMENT OPTIONS that says "Accept Standard Controllers for Volume and Pan". I can't remember if checking or unchecking is what sorts it. But if Kontakt is the VI, that's one thing to look at.
Topo
Post by Topo »
I'll give that a try....thanks
stubbsonic wrote:Kontakt has a setting in INSTRUMENT OPTIONS that says "Accept Standard Controllers for Volume and Pan". I can't remember if checking or unchecking is what sorts it. But if Kontakt is the VI, that's one thing to look at.
It's kind of an important solution if you are running multiple tracks into Kontakt and they are all sharing the same DP mix slider. With that fix, you can use the volume controls for each instrument loaded into kontakt, separately.
jimmy330
Post by jimmy330 »
Hi, I've just developed the same problem, vol-full pan-12 o'clock whenever Play is pressed. This happens to most of my plugs but not all. Ivory & EZDrums are immune. All Spectrasonic, Kontakt, & MOTU VI's are affected. I recently bought a new iMac i7 4.0Ghz, OSX 10.10.5 DP9.01. The solution with MIDI faders is a work around in the mean time BUT many DP users, myself included, have NEVER used MIDI faders, EVER! I regularly exclude them from my mixer cause it's too damn many faders! We adjust our VI's all the time, and that's where we set vol & pan, not with a MIDI fader. I need a solution that doesn't involve altering the way I've worked with DP since day 1. I have a call into tech support and they are going to get back to me. When I find out I will post their results. I know it's not the keyboard controller, (still did it with it unplugged). Might be an iMac problem? Any help would be appreciated.
iMac 27" Retna 4GHz, Apollo 8 w/Satellite, NI K-88 controller, plus a ton of VI's.
Tonio
Post by Tonio »
How odd, I'm having the exact opposite problem :shock: I'm losing about 6 to 10db's on playback, unless I insert a cc07 in the beginning of the MIDI track into Kontakt ( current).
When recording its at regular volume/ velocity of the tracks slider ?
Mac Studio MAX 2TB/ 64GB RAM / DP11.2 / 828ES//
MP 5.1 3.33- 3 duo / OS10.14.6 / RX580 /DP10.13/828ES
Maybe you are turning up the VI's volume (rather than turning it down). When DP resets the volume, you lose some gain?
Tonio
Post by Tonio »
yes sir, loosing gain on DP reset ( start from beginning beat 1)- I have Kontakt defaulted to -6, and DP sends it -12 or there abouts, unless I insert a cc07 in the MIDI track.
Will check all my pref's and automation set up I read about on the other thread(s).
