9.01 Lane pitch segmentation bug
- toodamnhip
When you highlight a segment in the Pitch Lane, and then use the “adjust pitch segmentation” slider to adjust segmentation, it does NOT display the NEW segment until you either re adjust the segment slider a 2nd time, or, you highlight some other part of the segment in the pitch lane, at which point, the NEW segment setting appears in the prior area you had adjusted. If you do not use a pitch lane window, i.e., you just use the pitch window without an added lane, the segments adjust immediately without problem.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- Shooshie
Re: 9.01 Lane pitch segmentation bug
Ahh... that's what's going on.
I've only used lanes a few times, briefly, but was troubled by something like this happening when working with pitch. (which is why I only used Lanes briefly) I'll go back and play with that some.
Thanks,
Shoosh
Thanks,
Shoosh
- toodamnhip
Indeed. And in 9.0 there were other lane bugs. I guess it’s to be expected for a new feature. The particle bug I reported here is minor and I could see it getting by beta. But I recall being rather surprised at the lane bugs that were released in 9.0.
It does indeed provide nice options for times when one is hunkered down with a long term task such as comping/pitching and volume-izing vocals. It is nice to have several windows showing. Same goes for CC data.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
