I've selected a range of notes in the MIDI editor, then using the "Set to..." popup menu in the selection information window, created a "new saved time" named "kickoff".
Now, I move on to other things, then come back to this area and select "Set To..." and "kickoff". Note that the selection start/end/duration are indeed set, but the data is not selected AND the edit menu items, cut, copy, erase, etc. are enabled BUT will not do anything.
I did find a little anomaly, in that if I actually select ANYTHING , ANYWHERE, then select "Set to..." and "kickoff", then the selection information is loaded AND the data is actually selected.
