Timing issues with DP MIDI & EastWest QLP
- Renaissance Man
When using EastWest Quantum Leap Pianos as a VI in Digital Performer, I've recently noticed some odd timing issues. Specifically, on a given piano chord with all notes at exactly the same starting point ( whether the MIDI notes have been quantized or moved manually ) the notes will still not sound at exactly the same moment.
If however I route the MIDI to an external sound module, for instance my Kurzweil K2600 keyboard, the notes in the chord DO sound at the exact same time.
I'm wondering if anyone else has encountered this or has any ideas.
Mac Pro Mid 2012 12-core 3.46GHz, 128GB RAM, Mojave, DP11, Waves Mercury & SSL 4000, VocAlign Project 3, Melodyne 5, EastWest Quantum Leap Pianos & Voices of Soul, Nomad Factory Integral Studio Pack, Slate Digital VCC, RC Tube & Trigger, & lots more plug-ins, MOTU PCIe 424, 3-2408Mk3's, 24io, MTP AV USB, Apogee AD-16X's & Big Ben, CraneSong HEDD 192, ATC monitors, tons of outboard gear & microphones, MIDI/keyboard rig, house drums & tuned percussion
www.nrpstudio.com
www.nrpstudio.com
- Shooshie
Re: Timing issues with DP MIDI & EastWest QLP
I wonder if that could be a latency issue in the particular VI you're using.
Shoosh
Shoosh
- Renaissance Man
This is odd. I can loop a chord (one that stands out as being particularly bad or easy to spot) and part of the time all the notes sound simultaneously, part of the time they don't.
I'm watching the meters in QLP - I'm using 2% of the CPU, a high of 40 MB/s of the DISK, a high of 21 VOICES, and it's assigned 287 MB of RAM. QLP isn't even breathing hard...
www.nrpstudio.com
www.nrpstudio.com
The dreaded "humanization" parameter?
I dislike such labels. I'm human enough; don't need a programmer making me less me and more him.
- Renaissance Man
What Shooshie said about latency got me exploring my settings. Eventually ended up in Set Up > Configure Audio System > Configure Hardware Driver and found my Host Buffer Multiplier was set on 2. Set it down to 1 and it stopped QLP's errant behavior.
Always has to be something stupid simple...
www.nrpstudio.com
www.nrpstudio.com
- Shooshie
Ah yes, I've encountered that in the past. I wish I could remember to suggest it when I hear of this problem. Glad you found it, and thanks for returning and posting your answer.Renaissance Man wrote:What Shooshie said about latency got me exploring my settings. Eventually ended up in Set Up > Configure Audio System > Configure Hardware Driver and found my Host Buffer Multiplier was set on 2. Set it down to 1 and it stopped QLP's errant behavior.
