m-audio projectmix PROBLEMS!
Having all sorts of audio problems with this unit. Just got it. Audio is breaking up, crackling. Can't sink it with my mytek converters without the audio breaking up. I've troubleshot all the obvious stuff: increased buffer, removed the mytek (converters) altogether. I'm just wondering if anyone else out there is using this box with DP with these problems. Maybe I have a bad unit.
Thanks,
j
Thanks,
j
- kelldammit
- Primary DAW OS: Windows
- kelldammit
i do not. i have a focusrite saffire, and i ran into a pretty similar problem. i was ready to give up and take it back when i happened across a rather generic "catch all" help hint on the motu website which said basically "if you're having problems, set the work priority to medium or low, and bump up buffers".
insofar as work priority, i don't think it necessarily degrades quality. there's a pretty good explaination of what it does in this thread:
http://www.motunation.com/forum/viewtopic.php?t=7802
it's one of the last posts on the second page, by magicd.
worst case, it's at least something quick and easy to try
kell
kell
By golly it worked Kell!
Thanks a bunch. I read magic Dave's explanation and it helped me to get past my worries about audio quality. I haven't tried "low" yet. I'll see if it stays happy on medium. I read here somewhere that audio quality goes down the drain when you take it off of high, but it sounds like it really has nothing to do with audio quality. I don't notice a difference in audio quality going from high to medium anyway.
Thanks a ton!
j
Thanks a ton!
j
- kelldammit
