Just updated to DP 4.61 using a PB G4 with 10.39. When I record audio and try to play it back there is no sound. I can see the wave file but can't hear anything. Is there a new little trick in this version to hear audio. I'm using coreaudio i/o.
Greeneye
Can't hear audio on playback!!!
if you are using a pci sound card as I am (Motu pci 324) I had the same issue. Try opening your MOTU PCI Audio Console and enable or put a check next to "routing" then save. Also, if enabled routing is checked, uncheck it and then check it and save. If you are on a different sound card or fire wire go to your configure hardware audio system/configure hardware driver change a few things, change them back and save. DP voodoo
Hope this helps
mbmusic
Hope this helps
mbmusic
Mac Pro 2.66, 3gig ram, HD192, 2408 mkII, DP 5.12, MTP AV, UAD-1 Studio Pak, Avalon 737, TLM 103, AEA R84, Great River MP2, Presonus M80, Roland xv5080, Pod Pro, EZdrummer, Ozone 3,
Many Lacie 160 gig external drives,
