V racks and Virtual instruments
Paulformer
Post by Paulformer »
A problem I'm having with my VI's in V racks is how to freeze tracks? Am I missing something? To freeze or even bounce a track you have to select the MIDI track and its corresponding v instrument track and if the v instrument is in a v rack I can't see how to select it. The freeze and bounce command stays greyed out in the menu. I really like using VI's v-racks but I have to freeze some tracks. Can anyone help please ?
Re: V racks and Virtual instruments
What I usually do is bounce, not freeze, and that works fine as long as the outputs match. I don't like freezing as it happens in realtime and essentially is bouncing at a slower process as far as I am concerned.
You might find this interesting:
http://www.motunation.com/forum/viewtop ... 11#p452111
frankf
Post by frankf »
If you return VI audio to an aux track, freeze should work. It does here.
Frank Ferrucci
http://www.ferruccimusic.com
Paulformer
Thank you both. I will be investigating further with your input (and output!)
