TAL Sampler, stuck notes *Resolved*
Hi I just bought ,downloaded and installed the TAL Sampler and it's associated presets.
Every preset I've tried sustains indefinitely(i guess stuck notes)I have tons of VI's & I've never had this problem this before.
I repaired permissions rebooted the Mac and no change, I'm using DP9 in 10.85.
Any ideas or suggestions?
Thanks,
KG
Thanks,
KG
- daniel.sneed
Re: TAL Sampler, stuck notes
Well, just guessing: Tal sampler reads sfz files. Not totally sure about what it is exactly.
Any chance to read some (or all) Alchemy presets?
dAn Shakin' all over!
Hi Daniel,I don't know what kind of files TAL uses or if you can use Alchemy files but I have no problems with Alchemy or any other VI's like this.
Will check thanks
KG
Will check thanks
KG
- daniel.sneed
Thanks Kgdrum. I'm just disapointed about Camel Audio closing shop. Meaning *someday* my actual Alchemy 1.55 and libraries wont run anymore on my future setup.
Any alternative to play Alchemy libraries means much to me.
- corbo-billy
I'm with the 1.3.7 version in demo mode and will not have this problem: you should write to this editor which is quite reactive or see the TAL Sampler updates. SAMPLER TAL is currently in version 1.4.1. _kgdrum wrote: Any ideas or suggestions?
Imac M4 24" under Sequoia 15.3.1 & Kontakt 8.2. _ Fireface800 X 2 _ FilterBank2 Sherman & Gibson Explorer Pro _ Virus C Desktop _ Adrenalinn III & Voyager Moog _ SpeakerPhone 2 _ PolyEvolver Keyboard _ Tempest _ D.P. 11.34 _
Thanks Billy,I will wait for TAL developers response ......hopefully tomorrow,I will also check to see if I can try an earlier version, if I can GREAT!
TAL Sampler looks really nice I hope to get this solved
daniel.sneed wrote:Thanks Kgdrum. I'm just disapointed about Camel Audio closing shop. Meaning *someday* my actual Alchemy 1.55 and libraries wont run anymore on my future setup.
Yeah all Alchemy users are keeping their fingers & toes crossed
Hopefully we all backed-up correctly.........
What I find intriguing with TAL Sampler (potentially) is the "vintage" sampler sound this VI goes for,IMO it's a totally different approach than what CA offered with Alchemy.......
Re: TAL Sampler, stuck notes *Resolved*
Update:
I decided to try removing the VSTs in the plugin folder and have DP re-examine as AU,now the TAL Sampler works as expected!
The TAL Sampler is a really nice VI,it adds a retro lo-fi texture to the palette that's missing from most newer VI's.
I never had an issue with a plug not working correctly as a VST and working as an AU,VSTs are set as my default format .
I'm assuming there's no reason not to trash the VST files, is that correct?
The developer Patrick is very talented and he was most helpful in helping me figure this out.
Thanks all for the responses.
KG
KG
- corbo-billy
Thanks for this following _
