DP9 - Cant select MIDI Track Output
wonder
Post by wonder »
In DP9, when I add a MIDI track or have an existing MIDI track, I'm unable to select its output.
I'll click on the output region and nothing will happen.
I have to Quit DP and reopen the session.
Its happening about 80% of the time.
Anyone else see this issue?
Dual Quad-Core 2.8 GHz Mac Pro 3,1 • Yosemite • 24 GB RAM • MOTU 2408mk3 (x's 2) • DP 10.xx • Finale 25 • Logic • PT 12 • +outboard gear
csavetman
Re: DP9 - Cant select MIDI Track Output
Post by csavetman »
Had a similar issue selecting MIDI device group. You might want to make sure the instrument you want to select is listed at the very top of the instruments list in bundles window.
toodamnhip
Post by toodamnhip »
I found a fix for this---highlite the track and hit Option A.
You’ll get a dialogue box and it will work even if clicking on a track output directly does not work. Once you use this command once, the MIDI track outputs will work again by direct click. It is a bug but this workaround is pretty easy.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
wonder
Post by wonder »
Great. I'll try this.
It's been a pain having to restart DP
toodamnhip
wonder wrote:Great. I'll try this.
YEs, that’s what I too had to do until I tried option a
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Dwetmaster
Post by Dwetmaster »
Ha ha! Thanks TDH :)
Sent from my iPad using Tapatalk HD
Phil O
Post by Phil O »
This happens to me when I have a MIDI keyboard in my bundles, but the keyboard it turned off. Turning it on makes the output assignable again. :?
yamguitar
Post by yamguitar »
This happened once to me as well. Quit DP and restarted, seemed to fix it at the time, but it was a bit bewildering at first.
4 GHz Intel Core i7 iMac Retina 5K, 32GB RAM, OS 12.7.4 • MOTU M6 • DP 11.31, Reason 12.7.4, Dorico Elements 5.1
