EZDrummer 2 Kit-Loading in DP 9 Excruciatingly Slow
Phaedrum
Post by Phaedrum »
Loading drum kits in EZDrummer 2 (as an AU plugin) is painfully slow within DP 9 on my system (Mac Pro early 2008, OS X 10.10, 8-core Xeon, 16 GB). In contrast, it is fast as lightning in both standalone EZDrummer mode and as a plugin in Ableton Live! Anyone else having this issue?
I recently purchased a SSD drive to try and speed up the kit-changing within DP, to no avail (although my Trilian bass samples and Garritan Personal Orchestra samples now load virtually instantaneously). The problem is clearly an interaction between DP 9 and EZDrummer 2. Any ideas as to the nature of the problem? DP acts as if it is loading small numbers of EZDrummer kit samples at a time (the progress bar inches forward over 1-2 minutes, whereas in standalone mode or within Live the same kit loads under 7 seconds!). Thanks for any help--trying out different kits is terribly frustrating as things stand presently (and even swapping out individual instruments is taking far longer than it should).
Mac Pro (Early 2008), 8-Core Xeon, 16 GB RAM, SSD & 2 HD, OS X 10.10, DP 9, MOTU 2408 MK 3, MOTU 1224.
Basstrup
Re: EZDrummer 2 Kit-Loading in DP 9 Excruciatingly Slow
Post by Basstrup »
I have had no problems regarding opening EZD, changing kits, eg from Default to Latin Percussion or switching individual instruments in a kit. The only thing I can thing of trying is switching DP between run plug ins in real time and pregen. Reason I say this is because EZD has a confirmed bug: outputs may become mono when the plugin window is closed in pre-rendering mode.
Should have an impact on opening performance, but when chasing the ghost.
good luck.
Analog is great... We got both WOW and Flutter - what's your bias?
MOTU: DP9 - 2 x MachV - 2 x MX4 - 2 x 1296 - 2 x 896HD - 1 x UltraLite AVB - 1 x MOTU Monitor 8 - 1 x 24i - 3 x MTP AV | UA Apollo Quad | UA Arrow | SSL 2+ || Digi 002Rack | Mackie control + expanders | UAD-2 PCIe card | 2 x Mac Pro | Mac Mini Late 2018 | OS X 10.14.6
Guitar Gaz
Post by Guitar Gaz »
Phaedrum wrote:Loading drum kits in EZDrummer 2 (as an AU plugin) is painfully slow within DP 9 on my system (Mac Pro early 2008, OS X 10.10, 8-core Xenon, 8 GB). In contrast, it is fast as lightning in both standalone EZDrummer mode and as an AU plugin in Ableton Live! Anyone else having this issue?
I have no real problems with loading kits in EZDrummer 2 - there is a timelag sometimes but mostly I choose the kit I want to use and tend to stick with it (ditto Superior Drummer 2) - then the song opens up and that kit is saved with the plug-in and re-opens. But I suppose there is a timelag as the samples are loaded - although you don't have a signature detailing your setup so it's difficult to tell whether there is any problem with hardware or system software.
Gary Shepherd
____________
Tesionman
Post by Tesionman »
No problems here either!
Get Real Live Drum Tracks @ http://www.hugoribeiro.com
Macbook Pro | DP 10.13 | Motu 8Pre (x2) | Apogee Duet 2
Sonor Drums | Sabian Cymbals | Remo Drumheads | Vater Drumsticks
billf
Post by billf »
I don't have any issues loading kits either.
This is troubleshooting/criticism. Belongs in different forum. Moved.
