plugins missing in DP9
I have just installed DP9 and most of my (third party) plugins are missing. I trashed the audio units info cache file but at reopenning DP9 didn't rescan the plugins. Then I opened DP7 and it did the scanning. Maybe the cache file for DP9 is located in a different place?
Mac mini Apple M1 ♦ 8GB RAM ♦ MacOS 14.4.1 ♦ Focusrite Scarlett Solo ♦ DP 11.31
- Robert Randolph
Re: plugins missing in DP9
Are they 32-bit plug-ins?nickysnd wrote:I have just installed DP9 and most of my (third party) plugins are missing. I trashed the audio units info cache file but at reopenning DP9 didn't rescan the plugins. Then I opened DP7 and it did the scanning. Maybe the cache file for DP9 is located in a different place?
How do I check that? But they probably are, so then what?
- Robert Randolph
I actually don't know how to check exactly (since I don't have any anymore), but if they are, you need to use an adapter like jBridge or 32-lives.nickysnd wrote:How do I check that? But they probably are, so then what?
Hopefully someone else chimes in with better info. I suspect this is your issue.
Thanks man!
Or run DP 9 in 32 bit mode.
Good idea, I'll keep that in mind, thanks!
