DP9 - Is Command+B really gone?
I've gotten so used to using Command+B to erase something. Now it seems that you have
to hit the "Delete" key on the Mac to erase anything. Is the old command really gone? Or is
there a way to configure it again in DP9?
http://www.davepolich.com
- Robert Randolph
Re: DP9 - Is Command+B really gone?
Do you know what command this referred to?
I checked a vanilla DP8 installation and it only corresponded to "Bold" in QuickScribe text.
I suspect it was a custom keybinding or very old keybinding for 'Erase', but it doesn't appear to be a part of DP8's default commands.
You should be able to search the Command window for "Erase" and add cmd-b to that.
- BKK-OZ
AFAIK, Command+B was always erase.
Dunno about 9, haven't made the plunge yet, but I always thought that Command+B for erasing was a quirky, silly shortcut, if its gone, good riddance.
Cheers,
BK
- M Kaku
BK
- M Kaku
- mhschmieder
I got thrown by that the other day too, but the menu shows you its replacement, which is the delete key off the main keyboard (the one near the numeric keypad). Works great and is easier/quicker to type than CMD-B.
- Robert Randolph
I've checked default installs of DP6 and DP8 now, and cmd-b wasn't listed in the Commands window. It also didn't erase MIDI notes for me, but perhaps I did something incorrectly as I was in a rush.BKK-OZ wrote:AFAIK, Command+B was always erase.
It's still easy to re-add it though. I don't see the issue here
It was never really an issue for me, just took some getting used to.
That clears up one mystery for me. Trying to repeat the bug some found in writing automation events, I found I could not delete these events on my MBP, but could on my iMac. The DP 9 installation removed the delete key on the small laptop keyboard, and only showed keypad delete key, which of course it doesn't have. So the delete key didn't delete.
Going to the default key bindings (which it should have installed in the first place because I don't have any custom binding on the MBP), the delete key now works. Even so, that key cannot be assigned to any command in the Commands window -- it has to be there already.
So this would appear to be an installation bug. That could account for some of the problems reported in other topics.
