Terminal is there, but is there a command to repair permissions?Simsy wrote:I have been using terminal today on El Capitan, is that what you mean by command line? Also had a good go with DP9 and it is running great.
Maybe you need to have DP9 installed before upgrading to El Capitan?
OSX 10.11 Public Beta - DP9 did not launch for me
Re: OSX 10.11 Public Beta - DP9 did not launch for me
- Gravity Jim
Yes, terminal is there.... but people with dev copies of 10.11 are saying that the two permissions-related commands are not available from the command line anymore.
Jim Bordner
chmod and chown are working fine. That's all I need to change permissions.
- Gravity Jim
Verify and repair are missing.
Jim Bordner
That's not the point. It's Verify and Repair.Simsy wrote:chmod and chown are working fine. That's all I need to change permissions.
It will be good for DP users if Repair is no longer necessary. Although Logic and Print drivers generate repair messages, only DP seems to not work if they aren't repaired.
