dp for the Pc
dp for the Pc
Are there any chances of DP coming into the PC scene. Would be really great........ R S MANI
Re: dp for the Pc
It would be great for PC users, no doubt as DP is a great program. I don't see it happening though, but you can never say "never." I'd recommend scraping some $$$ and taking the plunge and buying a Mac. Even if you only use it just for music-- in fact that's often best because you avoid problems from running all sorts of other programs, let alone using the internet.rsmani wrote:Are there any chances of DP coming into the PC scene. Would be really great........ R S MANI
Well, you could if Apple officially released OSX for PCs. However, their announced intention is to prevent OSX from running on PCs and only their Intel-based Macs. So you won't be able to run OSX on PCs... at least not with some illegal hack which would be illegal and unsupported.reekguitar wrote:well, why not? if OSX is made available to PCs?
Here we go....
DP on a PC? Since this whole wintel thing has happened your hearing more and more about people wanting to run OS X on their PC hardware (I think I even saw it running on a PC laptop on the net)...
Why? I'll always spend the $$ to get the real goods no matter what!
Think about it, I haven't heard many great guitarist (or performers in general) out there playing cheap instruments so why would someone want to be so cheap as to not put the proper amount of quidd into the heart of their studio! I mean, yes were not all rich but I know I have paid alot more in renting houses etc. than in the raw technologies to create my heart felt music! Plus, I dont think that the myriad hardware out there that most PC's utilize would really take advantage of the OS as Apple can do with their hardware and visa-versa.
OK, I'm done...
OK, I'm done...
- Newsles
I thought that DP for the PC was definitely on the cards at one point. There was a lot of talk on certain other forums (or is that fora?) about it.
When I was Mac-less I held my breath, thinking "at last, I can go back to my old, familiar platform and not have to shell out megabucks for a shiny new Mac).
Never mind
Never mind
I refer the Honourable Gentleman to the anwser I gave a moment ago...G4-upgraded G3, DP2.72, Korg 1212 card, Fostex 8-channel AD/DA converter, Korg DW8000, Novation Basstation, Kork M1rEX, Vintage Keys Plus, Akai S2000, Transcendent 2000 monosynth, Presonus ACP8 8-channel comp/gate, Behringer Multicom, Zoom and Yamaha external FX and a few other bits and pieces!
- Baptiste
hi everyone,
james Steele wrote:
I've got this Mac OSx86 version, I'm going to try this in native mode and run audiodesk 2 on my PC.
I'll send you here (and on the site above) the results of my tests.
Best regards
james Steele wrote:
as you said james, it's only an announced intention... I think it would be a real great commercial direction for apple and so a real great big kickass to microsoft and Mr Bill Gates if apple decides to officially release a version of Mac OS X for PC in native mode, because Mac OS X is the best OS in the world. And this version exists (actually called Mac OS X 10.4.3 v.8F1111A, codename Marklar), as you know, it is still developping by many people... (more information at http://www.win2osx.net/forum/). As you perhaps know to, people with bad intentions exist, and copies of a macOSx86 are unfortunately already sold in bangkok for 6 euros...Well, you could if Apple officially released OSX for PCs. However, their announced intention is to prevent OSX from running on PCs and only their Intel-based Macs. So you won't be able to run OSX on PCs... at least not with some illegal hack which would be illegal and unsupported.
Best regards
PC: P4 630 @ 3Ghz / Asus P5GD2 Premium / 1GB Ram(Corsair Value Select DDRII 512 Mo PC4200 x2) in dual channel
OS on 160GB SATA150 7200rpm Maxtor HD / Audio files on 200GB SATA150 7200rpm Seagate Barracuda HD
Softs: Nuendo 3, Waves-Platinum Bundle v4.0.
MOTU 896HD, MOTU MIDI express 128 USB, Alesis ADAT Black, KRK V6 series2 monitors, Behringer T1950 Magician, Roland TD6-K, Korg X5-D, SPD20, Yam A3000, and my musicians...
PS: Apologize for my bad english
No offense, and I hate to start one of the stagnant Mac vs. PC wars (especially not in herenewrigel wrote:why would someone want to be so cheap as to not put the proper amount of quidd into the heart of their studio!
I realize there are many who have had absolutely no problem with post-G3 machines, but the failure rate that I have personally witnessed here has been absurd, and would give no indication that they are using top of the line internal parts, or that their service, pricing, or replacement policies have changed all that much. I think there's a lot of "you get what you pay for" myth surrounding the platform debates. Mass production and a larger customer base often times means that parts are purchased for significantly less and can be sold accordingly. It would also seem that large companies who not only intend to produce a massive quantity of a board or circuit, but will also need to compete with an infinite number of alternative similar products, at or below their own prices, will likely spend the necessary time and effort to see that their own design holds up and is acceptably cooperative with other hardware and software. For family and friend's computers that I've pieced together over the years, if I haven't had a name brand board or card sitting around, which I've offloaded or upgraded from, I've often used notorious generic boards with less than optimum chipset performance,etc. With the exception of a maybe a PCI NIC and a soundcard of unknown history, *none* of this stuff has failed since it's been in service. It usually reaches the point of obsolescence and is replaced and/or given away. With the costs of much of that stuff, I've also admittedly grown quite careless in it's handling and installation. I rarely wear a ground strap or even bother to discharge myself while dealing with the parts, not to mention the wonderful treatment that it probably receives from the less computer savvy once it leaves here. My PCI/AGP cards are all jumbled together in cardboard boxes with nary a trace of static-proof baggies.
For modern Apples I've looked at, I will admit, they do spend some time on the case. The nicest case of my Beige machines was probably the Quadra950 and that was more for it's card/drive/SIMM capacity. The design was more or less a giant rectangle. I'd probably be crucified by most Mac users for this, but I've found surprising similarities between recent Macs and a few Dells that I've messed with or been given. They seem to have sort of stolen the case design, marketing ideas, and component priorities, yet probably at a lower average cost. They usually have a few proprietary parts and non-user accessible BIOS parameters, which prevent common upgrades and replacements, and the fancy cases are often incompatible from one line to the next, let alone with other standard ATX parts. I also haven't seen many recognizable brand names on the inside, but have heard that there are equivalent brand name motherboards for some, but the Dell boards are locked to their custom proprietary non-removable flash BIOS. The power supplies are also usually barely sufficient, with a high failure rate, and despite the fact that they use the same supply signals and connectors as standard ATX supplies, they've switched the pinouts around to prevent outside replacements, and maybe encourage users to buy new machines (no comment there). I'm pretty sure Dell has caught some flack for that and stopped doing it now, but I'm not so sure about Apple.
I hope this future processor thing helps to strengthen Apple's relationship and compatibility with the majority of the non-Mac world and opens up some options for host machine and part purchases, but I was convinced when the PPC's came out that we would soon be able to run either system's apps directly from our Macs, and it turned out we were lucky to even open some of their files.
Finally back on topic
Sorry for the long-a$$, potentially controversial rambling, but I guess it is an off-topic "gripe" forum. Audio people are audio people, and should be as open minded and experienced with both platforms as they are with the rest of their gear. Open standards, free enterprise and plentiful purchase options are ultimately a good thing for all of us.
-Take Care
George
I've used em all!
I have to admit... My G5 needed a processor and logic board swap out right in my living room by a mac tech sent from Apple and I was really bent @ that but in the end I was VERY pleased with the performance and the luxury of owning a tool that I can take my material to new heights. No matter what I wouldn't use a PC for my host (I do use em for Kontakt if I run out of DSP) but the reliability and just wierd anomolies that plague windows I just seem to loose the drive to make music with them.
- mhschmieder
I'm confused why OS X would have to run on a regular PC for this to happen?
My understanding from Apple's announcement last week is that the new Mac's might be capable of dual-boot.
So the bigger question would be whether the new Mac-tel strategy opens the door for MOTU to make DP and MX4 dual platform programs.
Of course I don't know how they're implemented, in terms of assembly-level code vs. Cocoa vs. whatever else.
The point is simply that one would have to know a lot of internals of DP to know what it would take to either make it work on Mac-tels or on PC's.
It sounds like you might be confusing underlying hardware with the operating system. OSX and Windows are two very different environments. The work to port a unix app to Windows is not trivial, regardless of who provides the chips for the CPU.mhschmieder wrote:So the bigger question would be whether the new Mac-tel strategy opens the door for MOTU to make DP and MX4 dual platform programs.
- mhschmieder
Actually, my point was that I thought the earlier poster was confusing the two
I know nothing of the internals of any of these apps, so cannot guess what any portn job takes, regardless of whether it is an OS change, a framework change, or a chipset change.
That's why I brought up the issue of what level most of these apps (and particularly DP) are implemented at. Many apps are simultaneously implemented on multiple levels, depending on the task at hand. Part of the app might be assembly code, part of it might be a Unix layer, and another part might be dependent on the windowing framework.
Depending on which level of programming the brunt of the app is written in, goes a long way to determining how disruptive to continuity or cross-development a change in the hardware (i.e. chipset), the O.S., or the windowing framework, proves itself to be.
The drivers increasingly are part of the O.S. when it comes to the Mac; whereas I believe they are still primarily vendor-provided on the PC.
Baptiste,Baptiste wrote:http://www.win2osx.net/forum/
I forgot to thank you for that pointer. My interest in OSX dropped off shortly after I realized it would likely require continual Mac upgrades, which I had already decided not to make, plus the version bundled with mine was while it was still in it's infancy (not very solid or compatible yet). I may investigate the PC one to see what all the fuss is about.
Unfortunately, someone pulled the plug on that site, for whatever reason, about a day after I read your post. I may be a jinx.
BTW- Your English is great. Don't worry about it.
-George
--------> I forgot--- Is there a replacement for that Win/OSX forum, or is it all dead now? My searches couldn't turn up anything.
- sdfalk
Why do you figure that?Jidis wrote:Baptiste,Baptiste wrote:http://www.win2osx.net/forum/
I forgot to thank you for that pointer. My interest in OSX dropped off shortly after I realized it would likely require continual Mac upgrades, which I had already decided not to make, .
Hi sdfalk,sdfalk wrote:Why do you figure that?
It already sort of had. Nine ran great on that machine, but those OSX builds were way too heavy for it (this was long ago). MS and Apple's current OS versions are never really being progressively optimized for last year's boards or chips, but Apple might be a bit worse in that regard. I was very disappointed to see the usual eye candy and bloat of XP, but there was continued support for 2K,98, and even beyond, from all the manufacturers, so I could upgrade my hardware and keep running 98SE, or upgrade my OS and still run all my apps or hardware. Plus, none of the upgrades ever required replacing my whole DAW. It was usually a MB/CPU combo and maybe memory, or could even be just a faster CPU. I hated having to prepare and sell off my rig at a loss, to try to keep up with the pack. Most PC DAW people don't care for 98SE, but I had always preferred it, and it treated me really well. It's small footprint, responsiveness, and stability was the same reason I really liked MacOS 7.6, but many didn't share that experience with it. To this day, I'll put it (actually 98Lite) on my online machines if I can, and may be using it on my secondary production rig at the studio. I didn't really get pushed into 2K/XP until Nuendo2 came out years later, and AFAIK, just about all the plugs still run in 98. That's pretty good lifespan for computer crap.
-Take Care
George
