Can't get bank b adat to show in mixer 16A
Indiescore
Post by Indiescore »
Hello, the mixer must be confusing me, I am running 48khz usb2 , 16A as an " audio interface only" but I have adat in and out of both banks, and using all 16 audio in trs, with just main out ( I don't see a way to turn off the other 7 audio out not in use ) .......per motu web site 48khz usb 2 should do 32 in, could someone help with how to turn on bank b adat? Only bank A shows under optical setup on device page, and the matrix mixer has me baffled as a long time pcie 424 user. Thank you
EMRR
Re: Can't get bank b adat to show in mixer 16A
Post by EMRR »
Is it selected as spdif? It's either/or I think.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
Indiescore
No adat is selected..but thx for the response.
Indiescore
So I checked the box and can see bank b ADT signal is coming into the motu mixer, but computer set up is limited to 24 and I need 32 in order for my daw to see ADT bank b, could someone advice how to get 32 from computer to device, device to computer turned on, this is audio interface mode.
Indiescore wrote:So I checked the box and can see bank b ADT signal is coming into the motu mixer, but computer set up is limited to 24 and I need 32 in order for my daw to see ADT bank b, could someone advice how to get 32 from computer to device, device to computer turned on, this is audio interface mode.
Do you have the latest driver software? Initially, USB was limited to 24 in and 24 out.
Indiescore
Yes that was it, the option for 32 is available now, thank you
:D
