Dormant mode for loaded ram?
comp15
Post by comp15 »
I created a large template with East West libraries with fifteen instances of PLAY. The track count so far is 205. However, the CPU grid in Vienna Ensemble Pro 5 is at 89%. Of course I won't use all the articulations for every piece but rather a combination. Is there a way in DP to unload the ram for unused tracks then, when needed, trigger the ram when that articulation is needed?
thanks
HARDWARE:
MAC HOST: 2.8 GHz 2010 Quad-Core Intel Xeon; Memory 32 GB OSX Ver 10.7.5
PC SLAVE: ASUS Sabertooth X79 ATX Intel Motherboard; Intel Core i7-4730K 3.2GHz Six-Core Desktop Processor; CORSAIR Vengeance 64GB Ram (8 x 8GB); Corsair Obsidian Series 900D CC-9011022--WW Black Computer Case; Steinberg UR22; Win 8.1
SAMPLE LIBRARIES (only on PC Slave): East West Hollywood Diamond libraries of Strings, Brass, Woodwinds and Percussion, Symphonic Orchestra, Pianos Platinum, Symphonic Choirs, RA
Re: Dormant mode for loaded ram?
DP 7 or 8?
Most of us haven't had to do this since OS 10.7 but I see that's what you are running. From an earlier thread:
To clear out RAM use the Terminal and type "sudo purge" then enter your password
OS 10.8 and later are much better at freeing up unused RAM.
